Question about Frigidaire GLRS237ZA Side by Side Refrigerator
GLRS237ZA REFRIGERATOR SIDE FREEZING ALL THE FOOD AND BEVERAGES. REPLACED MAIN COMPUTER BOARD AND IT STILL FREEZES EVERYTHING IN FRIGE. FREEZER SIDE IS OK.
    Novelist:
  • 121 Answers
Sounds like the tempreture thermostat in the fresh food is not sensing the tempreture properly, or the damper assy. is not closing or stuck open. you need to replace the thermostat for the fresh food section or the damper. their is a control box kit available
by frigidaire part # 5303918283 that will solve your problem.it has the fresh food thermost,the frz thermostat the damper and the board all together it retails for 235.99 -299.99. seen it at sears for 179.99. ,price just recently went up on these kits we still have one left for 129.99 + tax. + shipping . shop around and search for the best price .you will need that part # to search for part. good luck contact us if you need to orer or have any aitional questions. thank you
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE : allbrandsappliancerepair.com
email ; customerservice@allbrandsappliancerepair.com
Posted on Jul 11, 2008
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
Refrigerator side freezes and ice and water lines are frozen
the internal heater of the unit is not functioning and the defrost system allso check the mechanical timer of the defrost or if the unit does not have a mechanical timer it is build in in the PC board change hte PC board then it will go back to normal
Mar 23, 2013 | Frigidaire Refrigerators
Which way do you turn the dial for changing temperature control to make it quit freezing all our food
If there is a off position, That will be the direction to turn it higher. Make sure the seal on the door is working properly. It can cause ur problem
Mar 01, 2018 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Freezer is fine, however frige keeps freezing everything
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 14, 2011 | Kenmore 53642 / 53644 Side by Side...
Can i freeze food in a matsui mini fridge freezer with ice compartment?
You can do so but the freezing temperature may not be as good on a standard fridge specially for frozen foods as the mini is mainly meant for emergency foods and beverages.
Sep 25, 2010 | Refrigerators
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Kenmore Elite fridg freezing everything
Faulty Thermostate, shouldn't cost much to replace. good Luck , the Yeti
May 20, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Side by side freezer
Check that the freezer circulating fan is running. The frige section may have dampers or vents (lets the freezer air cool the refer section) that are open too much. Usually the bottom area in the frige has a control lever to meter how much cold air gets to that section (lots for meat, little for fruits, etc.). Check the owners manual for operation of those vent dampers.
Oct 22, 2006 | Maytag 60ADiW Side by Side Refrigerator
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
252 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
