Question about Whirlpool Duet GHW9150P Front Load Washer
Duet Whirlpool Washer
The control locked button is on and I can't use my washer. I held the pause cancel button. but the light is still on please help
You need to go to the right, to the end of cycle signal volume control button. Push it and hold it until the beep and it will go off. This is the "child safety" feature so that little ones won't interrupt your wash when they push the buttons. (and they will)
Michell~
Posted on Jul 11, 2008
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The control lock is on. I have tried unplugging it and pushing the cancel pause button and it is still on and I can't do anything because because it is all locked.
Hello
To unlock the controls you can reset the control by pressing the END OF CYCLE button and hold it for 15seconds. This is a common issue with whirlpool duet washers. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you get control lock off whirlpool duet washing machine
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock is on on my washer
The following link explains how to unlock the control panel on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is a designed safety feature of the washer that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can be inadvertently locked by leaning on the control panel, or during power outages. The instructions are printed on the front panel of the washer and are included in the owner's manual.
If these steps do not provide you with a solution, you may have a more serious problem than a simple operator intervention. Please let me know if you require additional assistance. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not start
This is joyce
Go to whirlpool.com and download your document to your machine and see what it has to say about your particular machine if that will help if not you may have to get some proff. help.
thanks
joyce
Feb 19, 2009 | Washing Machines
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
Feb 16, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal De
