You need three things to start engine, Air, fuel and spark. Check if there is spark by pullout ignition leads and see if there is fuel. Easy way to check is when you turn the ignition off you will hear a hiss sound when the injectors pump fule into manifolds. Alternately you can undo a fuel line and see if fuel pump is working. Best place check is at the fuel filter. If you dont know how to do it or not sure or anything please dont do it by yourself because there is a risk of electrical shock from ignition leads and risk of fire when dealing with fuel. If you have fuel and ignition then its crank angle or cam position sensor.
