Question about Frigidaire Dryers
How do you level this dryer (model# FEQ1442C)
  • 417 Answers
it may level like an old philco refrigerator, two big screws in the front? try turning them to see if that works
J
Posted on Jul 11, 2008
Leak at left side and front of lid model #8240ywo
Be sure and check if the flooring is in good straight flat surfaced,if it is,then re tighten all the screws/bolts around its body and it`s back,then put level bar on top of it,if it is not leveled properly,re adjust/turn the four legs of unit until you achieve the dead zero level on your level bar.
Oct 25, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My kitchen aid gas dryer timer isn't working. The clothes dry when I run it but the timer doesn't work - Model #KGYE670BWH0. Where can I pick up this part relatively cheaply?
Hello there and welcome to fixya
This is a really easy part to replace and it is rather cheap you can purchase it online at repair clinic.com
Timer
RepairClinic Item # 528733
Timer assembly for dryer
Manufacturer Number 3405331
More
Skill Level Skill Level
$118.30
Quantity:
Oct 14, 2013 | KitchenAid Dryers
Whirlpool electric dryer
Hello there and welcome to Fixya :
This is a fairly common problem with these whirpool dryers.
I will provide you with the 7 most common things to look for
which contribute to the symptom Dryer won't stop are listed below. Check or test each item and watch any available videos. If you are still unable to solve the problem you may need to do additional research and troubleshooting.
Show all parts for model GEW9878LW0 For the symptom you selected, these are the most common parts or causes, ordered by the likelihood of fixing the symptom.
othercausesandconditions.jpg Air Flow Problem The most common problem when a dryer is slow is when the vent is clogged. If the dryer is slow, check the vent from the back of the dryer to the outside of the house. If that is clogged, clear it completely and test the dryer. If the dryer is slow after the vent is cleaned, clean the internal ductwork of the dryer. This will require some disassembly.
blower-wheel-694089-00918612.jpg Blower Wheel
Item # 686172
The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft.
Part Replacement Video $23.40 Quantity:
In Stock
heating-element-assembly-3401338--00621237.jpg Heating Element Assembly
Item # 528055
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
Part Testing Video $91.05 Quantity:
In Stock
lint-filter-349639--00685658.jpg Lint Filter
Item # 2659
Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
$38.95 Quantity:
In Stock
moisture-sensor-279366-00565298.jpg Moisture Sensor
Item # 469522
Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or coated with fabric softener. Clean the moisture sensor contacts inside the dryer and th
Oct 11, 2012 | Whirlpool GEW9878LW Electric Dryer
Go to push start button and nothing. Have check breaker. Still on. And how do you level the dryer? It's a model:TEDS840PQ0
Number 7 is the fuse. If your dryer has enough lint built up in it the dryer will overheat and melt this fuse. You need to clean it up. Now here is an example of a dryer with a fuse probo:
How it goes back together:
Sep 19, 2012 | Kenmore Dryers
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
I have a Hotpoint dryer, approximately 5 years old, I can not locate the model number. The tub is banging during the spin cycle and it looks as though the tub is off center.
Check the levels by putting a spirit level on the top and adjust the feet to level, The model no. may be on the edge of the door, visable when you open it.
pete
Nov 22, 2010 | Hotpoint Dryers
I have a matag performa model PYE2300AWY dryer that wont start. Jumped out the thermal fuse, and door switch still nothing. Whats next? Timmer?? HELP
Could be a burned lead, timer might be bad, or the water level switch could be bad. (Water level switch enables motor operation when the level is high enough.) Hope this gives you a good lead to check... Good luck.
Nov 28, 2009 | Dryers
Dryer is not drying efficently
The heating element needs to be replaced. It can be done from accessing in the back of the machine.
Sep 17, 2009 | LG DLE2514 Electric Dryer
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
Foot,frount of washing mechine,both sides will not go down, to level mechine
The dryer is causing thiner material clothes to get brown marks on them. Severe sqeeking when dryer is on.
Sep 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
