Question about GE Hotpoint Top-Freezer Refrigerator
Ge refrigerator model PDS20MBSAWW
I Have a 2 yr old ge refrigerator that wasn't cooling properly. I took the back cover off & noticed the compressor was extremely hot & the condenser fan wasn't running. I disconnected the fan motor lead connector & checked for voltage...13.67vdc between white & red & the same reading between white & pink....the motor is rated at 11.5vdc & the tech sheet indicated 12vdc from the motherboard....I ordered this over priced ($200.00)!!! motor twice now....the 1st one I replaced didn't work.....so I returned it as "faulty" only to have the second not function either which leads me to believe??????? Can you help????
  • germaind Jul 11, 2008
    I have the same problem with my GE fridge. I have 13.5 volts between the red and white, and the same between the pink and white. New motor does not run. The motor windings ohm out at 1.700 k. Is my new motor bad? Any one know what the pink wire from the mother board is for?
  • rmarcum970 Feb 13, 2009
    I have the same problem with the same model GE refrigerator. Has anyone solved this problem? It's strange that the condenser fan motor connection has voltage but a brand new fan motor won't run. Does anyone know what the pink wire is for? HELP
    Novelist:
  • 121 Answers
Gee seems to me if your are getting the proper voltage witch you say you are sounds to me like a bad condensor fan motor. is the compressor running, maybe shut off because it was to hot.and you are right the motor voltage is from the board. we have had alot of mother board failures on the ge line. but that would be the problem if you were not getting power to the motor.on some models the power comes from the relay /overload hooked to the compressor. if the compressor doesnt come on and you hear a clicking from it every few minutes then you could have a bad
overload and relay that is mounted to the compressor.if thats all good then id say order another motor.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair.com
EMAIL customerservice@allbrandsappliancerepair.com
Posted on Jul 11, 2008
Should we repair 14 yr old ge profile refrigerator?
depends on what's wrong. if it's not cooling, clean the condenser coils with a vacuum, check the evaporator and condensor fans (easy replacement if necessary. if the compressor is shot or there is a refrigerant leak, say your good-byes.
May 14, 2012 | GE Refrigerators
My GE side-by-side refrigerator & freezer is not cooling.
Good day,
If it's been on for a while, the compressor should be warm. If the compressor has a relay box mounted on it's side, remove the cover, and pull off the relay, and overload and take them to an appliance parts house to be tested. If defective replace. If O.K. then .....
The compressor windings are out and the compressor is bad, or the motherboard on the back rear of the machine under a cover has failed.
Either case requires a service tech to properly test.
Jan 19, 2010 | GE GSS25LSMBS Side by Side Refrigerator
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Refrigerators
Just got back from vacation opened fridge door and wow, was greeted with god awful smell everything hot, i noticed the freezer temp was on zero, possible due to my four yr old but know cant get the...
if the freezer is at o then the compressor is working and frost buildup in freezer back panel check to make sure the cooling fan is working on the compressor area
Aug 19, 2009 | GE Refrigerators
The temp is set to the coldest and the fridge is just "cool"
try pulling out the fridge. Turn power off
1: Take the lower back cover off.
2: Inside you will see a Compressor, Fan, and a Flat coil that looks like a Radiator on a car.
3: Vacum all these areas really good. Dirt slows fridge cooling performance.
4: Replace Cover just the way you took it off. its important that the cover is on.
Hope it works
Please Rate Me
George
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not cooling properly/outside surface hot
please check the condenser fan motor. it is probably not running or the condenser is very dirty.
remove the rear cover and it will show you the compressor and the condenser fan.
if the fan is not running, try to rotate it manually and feel if it is sticking .
if it is, it may just need the old wd 40 lubricant.
tnx 4 using fixya,
drcool
Sep 07, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE HSS25GFP not cooling at all
May be a problem related to the compressor. Click may be the overload protector on the compressor tripping. If it is a problem with the compressor it should be covered by warranty if it is only three years old.
May 14, 2008 | Hotpoint HSS25GFP Side by Side...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
240 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
