Question about Frigidaire Kitchen Ranges
The indicator lights and clock on our glass top slide in stove work, but the burners and oven do not heat
  • 413 Answers
From what you are describing, the power to your stove is incorrect. The diagram indicates the voltages that should be present at the receptacle, I suspect one of the 110 volt legs is bad at the receptacle or circuit breaker. The clock operates on the good 110 volt leg. The burners need both 120 volt legs to be good because the burners and oven need 220 volts to work.
Posted on Jul 11, 2008
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
We have a Hotpoint RB787 Electric Kitchen Range. We experienced electrical issues/ power surge and now the oven part of the stove does not work. top still works and only indicators for the top burners...
you will need to replace the control board that contains the clock readout,any power surges ruins these electronics instantly,this can be replaced by removing the rear cover on the back of the unit and remove screws securing the electronic module
Jan 08, 2010 | Hotpoint RB787 Electric Kitchen Range
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Hotpoint glass top stove
sound as if you only have 120 volts going to the range check the voltage
Apr 12, 2008 | Hotpoint RB787 Electric Kitchen Range
Kitchen Ranges Logo
360 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
