Question about Samsung DVD-V1000 DVD Player/VCR
DVD Player won't open
When I push the open button nothing happens. The DVD portion of the player has turned into a dedicated player for the current DVD. Is there any way to manually force the player to eject? I am unable to open or close the DVD player portion of the machine.
I have opened the unit and removed the player.
I also found lose part(?)
I am unable to find where this part fits if it actually belongs to the player.
Any comments?
T
  • Anonymous Aug 30, 2008
    CANNOTOPEN DVD DRAWER
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check if your dvd door is driving by belt or gear . if its belt ,check if its slack, if gear check for worn gear. weather gear or belt check if the motor driving it responds each time you press the eject button .check if the eject switch is ok .then if all this are ok ,check the ic controlling the eject/close functions
Posted on Oct 12, 2008
My DVD player on my Sony Dav-HDX274 5.1 Channel Home Theater System With Dvd Player won't open. When I push eject (on both the unit and remote) it will read open or close and although it sounds like it is...
It sounds that the laser pickup unit to your HTS is faulty. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 16, 2014 | Sony Dav-hdx274 5.1 Channel Home Theater...
I have a sanyo dvd/vhs player and when you push the eject button to eject the dvd player it won't open. Help!
If you take off the top cover you might find that a drive belt that moves the tray is either off or broken. They are cheap to replace you just need to measure the diameter in MM and then enter "drive belt XXmm" into Google go for the nearest size to your measurement.
Jan 18, 2013 | Panasonic DVD-A110 DVD Player
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I have a Cyberhome CH DVD 300 (region 1), I want to change the region on this player. I learned I need for first: 1.- Turn On the DVD player 2.- The tray needs to be closed and empty 3.- Press the Menu...
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
Dec 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Can't get my CyberHome CH-DVD 300 working
Check for bad capacitors on the alimentation fead target
Sep 01, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD will not play when the play button is pushed
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Apr 11, 2009 | Toshiba SD-2109 DVD Player
Magnavox ZV450MW8A will not release disk
Unfortunately you'll have to remove the upper case and take a look. Sometimes you can see a gear that pushes the tray out. If you can turn this gear, the tray should operate. Sometimes you have to remove the upper portion of the drive mechanism. Remove it and remove the DVD, reinstall the top portion of the drive and reinstall the tope case.
Nov 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Try this. This works on some brands and models.
Power up the unit. Using the remote, press and hold the 'STOP' button for about 5 seconds. Release and press the 'OK' button.
Jun 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
NOTHING WORKS ON DVD PLAYER
My daughters had the same problem, try replacing C411 (I think that was the number on the board), its a 10V 1000uf capacitor in what appears to be the 5V power supply section toward the right rear of the main board, that fixed it. On hers the capacitor was swelled up on the end. I checked it out of the circuit and the DVM I used only indicated it had about 500uf capacity.
Sep 05, 2007 | Memorex MVD2042 DVD Player
Samsung DVD-V1000 DVD Player/VCR Logo
591 people viewed this question
Henry  Thomas
Henry Thomas
