SOURCE: Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Water dispenser works fine eliminates some potential probems, so disconnect the water line at the outlet of the water valve leading to the icemaker. Blow into the tube (with the freezer door open so the air has an escape route.) If you can't blow through the tube, check where the tube passes into the freezer section for an ice blockage. This would result from a water valve not shutting off 100 %, allowing a little water to dribble in and freeze the inlet shut. If you can blow through the tube, most likely the electric solenoid coil on the water valve supplying the ice maker water is bad. In either case, replace the valve. (it is a dual solenoid valve, part # 2315533)
SOURCE: water inside bottom of freezer after defrost cycle
your freezer drain is either frozen or clogged,remove stuff from bottom of freezer and you should be able to see the drainhole..if frozen use a hair dryer to melt,then to make sure it 's not clogged use a wire hanger to clear it out and you should be ok,let me know-mike
SOURCE: Kitchenaid Superba freezer side cuts out sometimes
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
