Question about Dishwashers
I can't get it to work i can trun it on but thats it. i can get work
  • eric bosman
    eric bosman May 11, 2010
    ?model and brand?
  • 417 Answers
Hi
could be several things,
are the dishes wet at all?
is there a puddle of water in the bottom ?
do you have children?
If the dishes are wet , then its not draining, up on top of the sink theres an aerator , pull the chrome cap straight up and under that is a white knob, unscrew that counterclockwise and look for debris, reinstall
theres a round white float inside the machine below the bottom rack near the front that can get stuck in the up position and prevent draining, grasp the float to see if you can get it to move up and down slightly, look under float for dishes/debris
look under the sink for kinked hoses with a flashlight, make sure all faucet knobs are turned on under the sink.
lastly, toddlers and small children can crank the control knob in the wrong direction, bending contact points in the timer, if thats the case , youll need a new timer..
good luck
J
Posted on Jul 11, 2008
Trun switch don't work put in new one still don't work
Turn signal, or trunk ?
Do you have power going to the switch ?
Jun 24, 2013 | 1989 Ford Taurus
When i trun the streeing seems to get hard to trun and sometimes then lock up for a sec...
check power steering operation at 3000 rpm, if it working properly, you need to replace yoru power steering pump. it is a very common problem on that year f150
Sep 06, 2010 | 2004 Ford F150
My laptop trun on for a sec but then it load for a sec and trun off and the fan working it just keep truning off it does not stay on to gmake it to the menu it trun off while it loads help
sounds like its had a knock and one of the heat sinks on the CPU or graphics chip is loose and overheating. It needs to shut of so as not to damage the CPU/graphics chip.
Jul 05, 2010 | Computers & Internet
Trun singles
Assuming that each signal only had two wires, it sounds like you are missing a ground on the side that makes all the lights flash. With 12vdc system, when you are missing a ground, the lights that are missing the ground will use the other lights on the circuit to ground themselves.
Sep 28, 2009 | 2004 Suzuki GS 500 F
Psp wont start
Might be the memory card inserted on your psp causing the issue, try to turn on your psp while the memory card is not inserted.
Sep 28, 2008 | Ubi Soft Asphalt: Urban GT 2 for PSP
How do i trun it on loud and speakers
I'm sorry, but I can't understand your question.
Mar 23, 2008 | Car Audio & Video
Kenwood KNA-DV4100 will not trun????
I had a similar problem, and found that it was due to not having the vehicle speed sensor hooked up to the unit. Once I did that, it started to work again.
Jul 30, 2007 | Kenwood KNA-DV4100 GPS Receiver
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
