Question about Konica Minolta magicolor 2430 DL Laser Printer
Error 2408 I have a Minolta 2430 dl and it ask me to install blk toner after install toner it has error line 2408 I have install other black toner cartridge but it ask me to install blk toner. now it ask me to install yellow,cyan, magenta. Before I got the massage I chk the status of the toner and it had 87% on black, 66%on color. can you help me? Thanks
  • nluid Jul 14, 2008
    Same issue, get error 2408. I also get the message "Panel Door Open, Front" when it is not. Along with these issues I have "XX Toner Cartridge not installed" errors. Is my printer done for?
    New Friend:
  • 16 Answers
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Posted on Jul 19, 2008
Hi, I am having a similar issue. I am trying to remove all my toner so I can ship, but after I remove one, I can't remove another one. It gives me an error.
Posted on Jan 11, 2010
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
2430 DL Kon/Min laser, b&w only
Hey
in printer menu you have to look up some setting and tell the printer to continue printing when toner emty, you'll find it in gualiti menu or engie menu, i dont remember exactly.
second i think you still need to have all toners installed, if C is installed but shows no toner, then you have to clean chip reader under the toner rack.
Sep 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Toner not installed problem Err: Line 2408
i have the same problem. my printer says all of the toner cartridges are not installed. i have taken each one out and returned them, and have rebooted the printer multiple times. nothing helps.
May 30, 2008 | Konica Minolta magicolor 2430 DL Laser...
Where are the Toner Contacs located?
On the right side there is a vertical **** with a square hole in the middle. If you push down inside that with a screwdriver, it will release the rack to rotate.
May 19, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
May 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Error code
toner chip is gone replace cartrige
Oct 08, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
1,538 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
