Question about Acer Aspire 5315 Notebook
Acer quit working
While using my laptop, it just turned off. Upon turning back on...it turns right back off. I cleaned my heatsink and fan, all ok. When I turn it on, the first screen starts to load...then shuts off. This repeats over and over. The laptop is less than a year old. Can somebody help?
  • Anonymous Jul 11, 2008
    Acer will not start. No boot to os no boot to anything. When I start...it shuts right down. Cna't even boot to initial screen
    Problem Solver:
  • 13 Answers
Are you running XP by any chance??
if so update the BIOS to the NEW 1.42 version
((the best version ACER has put out yet))
Posted on Jul 12, 2008
  • 3,940 Answers
Well, the 1st thing to check is boot into safe mode (F8 at boot) and see if you can get to the desktop.
If you can, run system restore and then see if you can boot to normal mode.
If it shuts down, boot to the system BIOS, and see if the system will continue to run, if it does, then your issue is most likely a operating system problem or a hard drive problem causing an OS problem.
If the system doesn't shut down in BIOS, next is try to boot to a CD. You may have to remove the Hard Drive to exclude it from the issue. If the system boots to a CD and will continue to run, then we are pretty sure the HDD/OS is the issue.
Next would be trying to run diagnostics on the hard drive, if they fail, replace the drive. If they pass, reinstall WIndows.
Posted on Jul 11, 2008
My acer asipre 4739z laptop starting after a few minutes not work. fan is running battery is ok
Please describe a list of events that takes place from the time the ON button is pressed until the screen goes OFF. Attach an external monitor and press the Function key with the screen key to transfer video. If monitor responds the video is OK but screen is BAD. Then replace Screen. If Monitor does not show video then problem is probably a thermo problem. To correct video chip overheating do the following; First ... Remove Battery. Remove CPU and Video Heatsink and Fan. Clean dust and lint that is blocking airflow in heat transfer grill. Clean dust from inside fan. Clean old heatsink grease from Heatsink and from Video chip and CPU. Apply fresh High Quality Heatsink grease evenly but sparingly to chips. Replace Heatsink following tightening order to spring screws at CPU. Replace covers ... and start.
Aug 30, 2013 | Acer 6-cell Battery For Aspire 4739z,...
Tip
How to keep your laptop clean and cool.
The most important part of your laptop that needs to be clean is... the heatsink. Yes, heat is the "cause of death" for most laptops. The heat not only causes all components to expand and contract a little (as you turn it on and off), but will also reach dangerously high levels and make your laptop crash or shut down if the fan(s) and the heatsink(s) are clogged with dust.
For desktop PCs this process is somehow slower and less noticeable as there is a lot of air circulating inside the case, hopefully with both intake and exhaust fans pushing it through. Also the CPU heatsink and fan are quite bigger and more powerful. There are also fans on the power supply, on the video card and probably on the chipset, for a total count of up to six fans making sure your PC stays cool. However laptops usually have just one or two smaller fans that have to do it all.
I would suggest a little experiment. Look around you for a lamp with an ordinary 100W light bulb. Now turn it on for five minutes and hold your hand about an inch away from it (be careful not to touch the bulb, it will scorch you!). Do you feel it? Yes, that is the heat generated inside that shiny new powerful laptop you just bought.
The cure? It's easy: get yourself a can of compressed air and blow away the dust off the fan and heatsink. This has to be done every couple of months or after about 50 - 60 days of using your laptop. The compressed air is quite handy for the keyboard too, blowing away all the debris from between the keys. This is not a very well known fact, but it is the most important part of maintaining your laptop.
However if the heatsink has already been clogged, this won't help. The compressed air will not be enough to unclog it. If you have never cleaned the heatsink and you had used your laptop for over a year, chances are that both the fan and the heatsink are clogged with dust and debris. The solution in this case is to remove the heatsink, clean it and install it back. This is best done in a laptop repair shop, as it takes quite a lot of experience and dexterity. One slip of the screwdriver may kill the laptop!
Some newer laptops have a special removable cover on the back for easy access to the heatsink. But most laptops have to be disassembled to reach it. Another problem is that the thermal paste between the heatsink and the CPU hardens with higher temperature, so if the laptop has been overheating, chances are that the heatsink is stuck solid to the CPU, making it very hard to remove. The process also includes removal of the old thermal paste from both the CPU and the heatsink and applying a small dab of fresh thermal paste, preferably silver filled for better heat transfer.
Another good overheating prevention is to ensure that the rubber feet on the bottom of the laptop are intact. Unfortunately they are usually just glued to the plastic and tend to fall off quite easy. They are very easy to replace and are available as spare parts for most laptops.
And lastly - don't use your laptop while it's on a soft surface, like bed cover or sofa. That will block the fan and the laptop will overheat. Try using something with a hard surface under the laptop, like a large hardcover book or a tray.
Simply put, heat is the biggest enemy of all laptops. By maintaining the cooling of your laptop at peak efficiency, you are doubling its lifespan.
for more tips please visit http://www.bootmylaptop.com
******Please Vote for this Tip if you found it helpful.
on Dec 16, 2010 | Computers & Internet
I have recently replaced the bezel and LCD cover of my Dell 1737 laptop. Upon turning ing it on, however, the fan spins very fast and of course is very loud. I was wondering if anyone may help me...
its normal for fan to turn really fast during start-up but if it stays that way means, your unit is very hot and the system is continuously trying to cool it down. open the bottom cover and clean the vent this might fix the issue apply thermal paste of high quality if you have some. it can greatly reduce temp up to 5 degree instantly. as to your question whether its fan or heatsink problem, i assume it is fan. heatsink is passive and less likely to have problem
Aug 06, 2013 | Dell Studio 1737 Laptop
Acer aspire 5741 overheating then it shuts off
heck to see if the fan is working, if not replace it.If the fan is working and spinning freely, then clean the vents and remove any dust/lint.You may need to remove the fan/heatsink off the CPU and clean off the old heatsink compound and replace it with fresh heatsink compound and reinstall the fan/heatsink.
When using the laptop, make sure it is on a firm flat surface and none of the vents are obstructed.
Oct 23, 2011 | Acer ASPIRE 5720-4649 Notebook
Acer notebook turned off
Its very likely it is overheating then. I think there is a panel underneath the laptop which you can remove and have access to the heatsink and fan. See if you can get some compressed air and blow away the dust that has accumulated in the fan and heatsink. That should solve the problem for you. Don't use any cleaning products on it and be very careful. Take the panel off, and if you dont feel comfortable, seek help from an experience technician or a repair company such as www.revivemylaptop.com
Jun 09, 2010 | Acer Aspire One PC Notebook
Shuts down will not turn on at all
The first thing you need to do is clean the heatsink on your laptop. The heatsink is a piece of metal that dissipates heat away from the cpu, and is cooled by the fan on your laptop. If it's overheating and shutting off, it's either a clogged heatsink, or the fan is not turning. Get a can of compressed air, or use an air compressor if you have access to one (set at 80 psi).
You need to blast air into the grill on the laptop where the hot air comes out. This will likely cause a cloud of dust to come out of the bottom of the laptop where the fan is. This is a good thing. Also, remove the battery from your laptop and plug in the power cord. If it still won't power on when plugged in (with no battery) then the laptop is likely dead. Acer will usually repair a laptop for $199 so this may be the way to go.
Let me know how you make out!
Joe .
May 09, 2010 | Aspire Acer AS5315-2856 Laptop
I have an Acer Aspire 4520, Will not turn on.
IT COULD NVIDIA DISPLAY IC PROBLEM,GET IT REPLACED.
DHARMAKKAN
Feb 19, 2010 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5570
Hello Norah,
A google search with the Laptop Model and Part number from the Fan/Heatsink is always a good place to start. Also, ebay can turn up some really good deals on laptop parts. Here's a link to a Fan/Heatsink combo I found using a Google search within the shopping section.
Acer 5570Z Fan/Heatsink
Hope this helps and good luck with the repair.
Leave some positive feedback if you found this to be helpful, thank you.
Feb 16, 2010 | Acer Computers & Internet
Can't boot up my acer 290 notebook as the screen is
Hi,try making sure your heatsink is properly seated on your cpu chip with some cpu compound between them......I had a laptop that did the same & when i checked the cpu heatsink & fan i noticed the screws holding down the heatsink onto the chipset had come away so i applied some compound to the centre of yhe chip reseated the heatsink with longer screws & i also gave the heatsink & fan a good clean,put it all back together & it worked fine...goodluck
Jun 06, 2009 | Acer TravelMate 290 Notebook
Toshiba Satellite M115 cooling problem
You could use canned air to try and blow it out
make sure you don't turn it back on for about 20 minutes
Jan 24, 2009 | Toshiba Satellite A135-S2246 Notebook
Acer Aspire 5315 Notebook Logo
176 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
