Question about HP Compaq Presario V5000Z Notebook
Laptop isn't working
My daugther has a Compaq Presario v5000, it isn't working. I purchased a new battery thinking that was the problem. I have had it charging for over two hours.The only response I get when I try to power up is a flashing light. My daugther says that its the signal to charge the battery. Nothing shows on the monitor and it doesn't make a sound. She has had this laptop since Dec. 2006 and has been very active on it, including leaving it on overnight. Is there any hope of saving this laptop or has she fried her first laptop.
  • josephvss Nov 19, 2008
    I have a V5000 (Turion) behaving similarly! Charges the battery but no beeps; Fn+F4 works (screen brightness) I wonder what did busted on the MB
  • 550 Answers
Have the charger tested, the original battery may have been flat, because of charger failure rather than battery failure. try an automotive connector if one is available
2c worth
Posted on Jul 11, 2008
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
Hello GOD BLESS YOU all. my latop is compaq presario V5000
You can download latest drivers for your model here
Apr 09, 2009 | HP Compaq Presario V5000T Notebook
Hi my name raji I have a laptop ... compaq presario v5000 wel its touch pad scroll is not working what can i do
their is only one solution for compaq v5000 as you have to buy a usb port small mouse.
i mean that you have to purchsae a new mouse.
George_raji
i want to ask a question that wheather you touchpad has been coloured off by using it.
if yes than tell me yes?
Jan 03, 2009 | HP Compaq Presario V5000Z Notebook
Laptop wont turn up
Check the adapter.If it is good then its the DC jack.The only other thing it could be is the motherboard.
Oct 27, 2008 | HP Compaq Presario V5000T Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Needing to fix a compaq presario v5000
The screens on these computers can and will go dead after a while, afterall its an old computer..try an external desktop monitor by plugging it in the back(blue port)
If you want a new screen go here
Good luck..and if you have any questions about your armada just ask.. I have 5 of them.
Oct 01, 2008 | Compaq (241995001) Plug-In Module (Laptop)...
V5000 problems
what you need 2 do is either take the whole laptop back 2 where you brought it or even the battery cause you have a faulty battery.
most laptop batterys last for at least 5-10 years and after that no matter how much you charge them up they alwayz seem to be flat.
so my suggestion is get a new battery or take it back to the place that you brought it from and than get it replaced for free as long as you have your recept.
Jul 06, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Replacing harddrive
Service Manual of V5000:
http://h10032.www1.hp.com/ctg/Manual/c00700903.pdf
Service Manual of V2000
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
yes the hdd of the V2000 and V5000 is interchangeable. it uses both IDE type hdd.
Apr 11, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000Z Notebook Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
