Help!!! I inserted papers to shred and everything was going fine until about the 10th paper. It got stuck mid way and the machine turned off. I cleaned all the pieces on the inside and turned on the machine once more and still the paper is stuck and not being shredded. The green light is on but its not not shredding the paper that's stuck inside!! What should I do??? Someone please help!!
You may have paper stuck in the blades and its jamming.try forward and reverse to free it up or you may have the head unit on the can faced the wrong way. Pull it out and turn head around and than try. I know on some shredders if the head unit does not fit on the right way it wount push down the safety switch and it wount run.
Sometimes the sensor gets blocked by pieces of shredded paper. Unplug the unit and remove it from the paper bin. Turn it upside down and see if there are any "stray" pieces of shredded paper hanging on the unit. Remove the stray and replace the unit onto the bin making sure it is properly seated. If that is not the problem, try "tamping" the shredded paper into the bin and by doing so, giving the machine more room for the shredded paper. If neither of these help, refer to your owner's manual to see what recourse you may have.
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
As a test try shredding into a small box or even the cabinet itself with the bag holder and bag removed. Just to see if these are causing the problem.
The bag Full switch is activated by an arm which is pushed up by the pressure of the shredded paper in the bag as it fills.
When a sheet of paper is shredded, after the trail end of the paper goes past the "eyes" the machine should still continue to run on for a few seconds to drive the shredded paper out.
You dont say make or model so...get some shredder oil into the cutting teeth where you insert the paper...especially if its a x-cut shredder..make sure once in a while you shred a piece of paper with some of the oil poured onto the paper for lubrication of the cutting blades.
When the paper shreds it pulls both the blades inward. Reverse spins them outward.
There must be something too large between the blades because it can be pushed up just not pulled down.
Has a staple or paperclip been inserted into the machine?
Try one of these two things:
When you're vacuuming the machine, hold the reverse button in and see if that helps.
Unplug it, take out all loose pieces like the bag liner, tape the door closed, get another individual to help you flip it upsidedown and GENTLY tap the machine to break free any obstructions.
Hopefully one of these solutions will work for you.
