Question about Goodman Heating & Cooling
My air conditioner will blow cold air for about 3 hours, Then it keeps running but no air is blowing at all. It's done this 3 times this year already. Thanks, Derek
  • 828 Answers
If you live in a climate where temperature drops in the evening and night time hours run the system with the fan in the on position. This will allow any ice buildup on the cooling coil to melt in the off cycle.
Posted on Jul 11, 2008
Are trailer is only a couple of years old and we have only used it a few times - twice when we have used it we left the air conditioning running and left the trailer for a few hours and come back and it is...
Here is what happening . This has nothing to do with you having it on while you stepped out for a few hours. The unit needs to be cleaned/ filters/screens/fins/coils. This problem would of happened even if you were in the trailer as it was running. The issue is after a while, sense it needs to be cleaned it loads up and then starts to freeze and then once it starts to freeze coils etc... it then starts only blowing warm air. When you turned it off, and let it set for a while, reason it started working again, is because the ice that built up defrosted some to have unit operate proper again. Solution is to clean the unit good. Thanks Mike from fixya.
Jul 31, 2011 | Dometic Rooftop RV Air Conditioner
My air conditioner is not blowing cold air. What can be done ?
look for a couple of things ... if the compressor just buzzes intermittantly but doesnt run then suspect its starting capacitor (small rounded metalic rectangle) .. that has wires connecting it to the compressor .. .. if you can hear the compressor start but it still doesnt cool then you likely need refrigerant added .. thats done by adding a saddle valve service port ... any leaks have to be repaired ..
Jul 25, 2010 | Haier Mechanical Air Conditioner HWF05XC7
I have a 2002 Acura RSX that has AC Problem. Blows very cold air, but not all the time. As long as RPM is running at drive speeds, I have cold air. However, at stop lights the air temp goes warm. If I...
your ac compressor is freezing up try not putting it on cold all the way. put thermostat towards the red jus a lil but still on the cold side to see if that helps
Apr 03, 2010 | 2002 Acura RSX
Not blowing cold air
unplugged the unit, kept the doors closed about 10 to 12 hours plugged back in and in about 2 hours started blowing cold air into freezer another 4 hours was blowing cold air into refrigerator and continuily got back to the themostat settings,about 1 day. no food was lost because the doors were closed still keeping it cold. i think the fan in the freezer was frozen with ice,but could access it, not the main fan in the back the unit by the compressor,that was running fine. so basically i defrosted the freezer fan by unplugging it. this is the 2nd time in 4 years ive done this, well it beats spending 1000-1500 dollars to replace it TRY IT I HOPE IT WORKS FOR YOU BEFORE YOU CALL FOR SERVICE,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Apr 18, 2009 | Fujitsu 24R1 Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
100 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
