Question about Insignia LCDTV26 26 in. Television
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
I am trying for few weeks now to direct the sound of my LG HDTV to my home theatre. I am desperate as I've tried everything without success.
Please help me or direct me to whoever can be helpful. I can wait to enjoy my new system and have my home theatre couple with my LG 52" HDTV turm my living room to a real home theatre.
Thanks for your help in advance
You can email me at wnibl@yahoo.com. same problem i am trying to connect the tv to surround sound theatre
Flemflam-   There is a couple of options here. If you are using a DirecTV Receiver or a box from the cable company then you want to run the Audio out lines to your Audio/Surround Sound Receiver. If you are running cable directly into the TV then you want to use the Audio Out Plugs on the TV. In some cases there is no Audio out but there is a Headphones out. In this case you can run a Mini-Plug to Composite Audio cable to the receiver.    You can also Call 1-800-GeekSquad and they will dispatch an Home Theater Installer to resolve your problem! They are great for Turn Key Solutions!
Posted on Jul 11, 2008
Sound Problem
I'm unclear about the comment"If I play a DVD or net fix through separate box" What do you mean by separate box? Please reply.Be specific about what inputs on the tv and what settings you have check in menu as far a sound id concerned.
May 31, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lg plasma 50 trying to configure hdmi to play tv sound through panasonic home theater.
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Dec 13, 2010 | LG 42PB4D 42 in. Plasma HDTV
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
No picture just sound thru dish network
There are a few reasons that this could happen. The main reason would be that the tv is on the incorrect channel or input. You will want to make sure that if you are at TV1, the channel is on 3 or 4, and an input if needed, such as VIDEO 1 or 2. If at TV2, the channel needs to be on 60 or 73. Cabling is another reason this could be. You want to make sure that if you are at TV1, all cables going from the receiver to the TV are connected on the back of the receiver at the green TV1 location. For TV2, the cable needs to be connected to the HOME DISTRIBUTION output on the back of the receiver.
Becki Barned
DISH Network Customer Service
Jun 01, 2010 | LG 52LG50 52 in. LCD HDTV
MY TV is LG 42 PG 60D , serial number :803KCBD35285
Sound like ur Tuner board have intermitint problems,it work awhile,than the old problems occur again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Because this problems come and goes.
Apr 30, 2010 | LG 42LC2D 42 in. LCD HDTV
Have new LG 42" LCD and no sound on the 5.1 Surround Sound
Try running a set of audio cables(Red/white) from your audio out jacks on the back of your TV to your reciever's audio in?
Feb 01, 2009 | LG 42LC2D 42 in. LCD HDTV
Model p46770ck rca home theatre
sounds like a bad flyback on the circut board (a common problem) part is around 70.00 but they will get you in labor
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mini Home Theatre - FB162 - HELP!!
If I am not mistaken, you would have to connect the yellow video from home theatre to your yellow video on the TV, doesn't sound like your TV has the Component video capability/
Sep 28, 2008 | LG 42LC2D 42 in. LCD HDTV
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
Sound problem!!!!
remove the cable box and try w the cable direct to the tv if the problem desapear bang you cable box need to be replace
Nov 29, 2007 | LG 42LC2D 42 in. LCD HDTV
Insignia LCDTV26 26 in. Television Logo
147 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
