Here is a video to walk you thru the troubleshooting process.
Not knowing the model and year and assuming it's a gas dryer you need to replace the dryer ignitor coil. This is what ignites the gas electrically since they done away with pilot lights. It's not a hard fix by removing the back panel and they can be bought from Sears.
Good luck and thanks for your question and I hope my suggestions help. Don't forget to rate me.
burdfrenzy
Visit My eBay Store! http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
