Replaced black/white & color ink cartridges. Screen reads "Carriage jam. Open door. Press enter." Do as asked, still will not continue into print mode. Makes noise trying to move into place. Received as a gift in either 1999 or 2000.
- clogged toner that was sitting there for a while
- wrong toner installation orientation
- wrong toner compatibility
removed the newly installed toner and clean the unit that goes with it with a vacuum cleaner, be careful not to spill the toner onto your carpet, pls make sure that the toner you installed sits comfortable without any resistance or any signs of abnormality,
if it does then this may not be the right one for this.
carriage jam is an indicator that it wasnt correctly installed nor replaced
Don't know how to make the second sort option work. The option is to rotate every other set of...
(More)
Don't know how to make the second sort option work. The option is to rotate every other set of copies 90 degrees. It will only sort, not rotate, loading second drawer with paper rotated did not work.
Hi, I am receiving an E-1 error message on my FT5832 copier.Then when i press gain to (,)to know...
(More)
Hi, I am receiving an E-1 error message on my FT5832 copier.Then when i press gain to (,)to know more about this eror i receive 41.. please give me a solution thnk u
getting printer under preparation and can not print to it. This is a sharp ar-810 and I have a...
(More)
getting printer under preparation and can not print to it. This is a sharp ar-810 and I have a Parallel cable hook to it
It pulls the paper back as another pap[er comes out also making a very funning noise when it moves...
(More)
It pulls the paper back as another pap[er comes out also making a very funning noise when it moves to print. Also would love to buy another hp 190 copier
