Question about Konica Minolta DiALTA Di200 Copier
Di251 error code
I moved my copier from one location to another. Since then everytime I turn on the machine from off or standby I get the following error messge
!*! ABORT !*!
code =0x00dc0652
tskid=0x00005849
sp=0x903c5738
ra=0x9f5e9fdc
build 0692.010329
Then the copier will recycle and then repeatedly display above message until eventually I give up or the copier works. Please help
Most popular solution is you resigin your job hahahah
Posted on Oct 22, 2008
Minolta di 251 error code c133a
Electrical disconnect Draws #2 draw #3 draw #4 and Draw #5 all connections for each of those draws is in the rear middle cover. Also remove the job tray that the device where the paper comes out for faxes print etc. leave only draw one connected power off the machine turn back on after ten seconds. if the code is gone have a bad draw (s) if it comes back replace the main board if you can find one. The Di251 is legacy machine Minolta is now Konicaminolta. If the code did not come back your going to start connecting each draw back one at a time. Fig out which one(s) is causing the problem
Feb 06, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
Minolta Di251 All-In-One Printer windows 7 64bit print driver
SORRY Di251 is a Legacy Minolta machine. At best can only use windows 95 or Xp. Minolta is Now KonicaMinolta
Dec 10, 2012 | Minolta Di251 All-In-One Printer
C00500 code what to do Minolta Di251 Thank you
Ispyvolvo, First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Aug 09, 2011 | Minolta Di251 All-In-One Printer
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
C0500 error in a minolta Di251
Does the lid over the toner bottle close properly?
Feb 26, 2010 | Minolta Di251 All-In-One Printer
Minolta di251 c0650 code
Hello sir; This problem caused by home positon senser problem, replace it.
Aug 25, 2009 | Konica Minolta Office Equipment & Supplies
Malfunction detected, code CO500 on our printer, model Di251.
my di2010 has a co500 code on it after someone tried to run a transparency thru it.
Jun 25, 2009 | Minolta Di251 All-In-One Printer
Machine Error e1-20 is being displayed after copier was moved.
That error is related to the laser unit. Check your connectors, they may have vibrated loose during move. These machines have a history of laser units going bad.
Apr 15, 2009 | Panasonic FP-D250F Copier
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta DiALTA Di200 Copier Logo
708 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
