Question about GE JVM1340AW/BW/WW Microwave Oven
Will not run
Everything works as far as the electronics goes, the timer counts down as if the oven is running, but the turntable, fan and magnetron does not work.
  • Anonymous Dec 26, 2008
    i HAVE THE SAME PORBLEM AS ABOVE WON'T RUN TESTED THE SWITCH FOR CO NTINUITY IT TESETED GOOD OCULKD THE SWITHCH STILL BE BAD?
  • Anonymous May 05, 2009
    everything works on it, except the cooking part. Only get a hum.
  • GE Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 11, 2008
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
Ge jvm1650bh01
Hi, You need a new Magnetron gun installed in the microwave.
It is burned out and needs to be replaced. You will have to call GE for parts. Good luck.
Jan 13, 2014 | Microwave Ovens
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
The fan works, the light works, the turntable goes around, the timer counts down, I can adjust the power level but....it does not heat up! Anything else I can try to make it work?
Your magnetron has failed. The microwave will have to be removed off of the wall and disassembled, the magnetron is located on the right side behind the control unit. This is a pretty extensive repair if you haven't done it before. You can do it yourself or hire an appliance tech to do it for you. You can order a magnetron from http://allapplianceparts.com/magnetrons2.html and I would suggest getting the diode as well. You can look up the diagram on your microwave http://www.apdepot.com/index.asp and see how it comes apart.
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Nov 24, 2009 | DCS CMO-24-SS Convection/Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything seems to work fine until you hit the start button than nothing happens except the timer starts counting down
If everything appears to be working normally, as you say the timer counts down, the light comes on, turntable rotates etc. then the problem will be linked to the magnetron not operating & not heating the food. This could be just a thermal fuse device which may have gone faulty but if it is a magnetron fault then the cost of getting this replaced can be expensive & it might be more economical to buy a new microwave. I would advise taking it to a local repair centre, one which gives free estimates to get a quote on a price.
Jul 27, 2009 | GE Microwave Ovens
My over the stove microwave will run however no heat. Popcorn digets do not count down but set numbers do. odd odor.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Dec 11, 2008 | Microwave Ovens
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Oct 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
GE JVM1340AW/BW/WW Microwave Oven Logo
117 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
