Microwave Ovens Logo
Posted on Jul 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ge microwave after running for about 3 to 4 minute it shuts down and will not start up again for 30 minutes model # TH903659B JVM 1650 JVM 1651 what is the problem thanks
Tim martin
Level 2:
  • Expert 100 Answers
  • Posted on Jul 11, 2008
Tim martin
Expert
Level 2:
Answers
100
Questions
0
Helped
46531
Points
155
If the fan comes on when you put the unit into a cook cycle and all sounds normal otherwise, you most likely have a bad magnetron tube. (Google "GE magnetron failure" and watch how many complaints and articles pop up). The tube overheats and trips the thermal relay causing the unit to shut off until it cools back down and comes on.
Very, very common problem on these models although GE will not admit it.
Richard Beck
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jun 12, 2013
Richard Beck
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
13992
Points
23
Check this ouit first before you go out and buy a new mag:
The mag's little cooling fan probably broke loose and fell off the fan motor's shaft. The fan motor will still be running when you hit start but there is no fan on it. The fan keeps the mag cooler. The mag will heat up too much and then shortly the oven automatically shuts everything down when the mag gets too hot because the fan blade is just lying in there, Fan needs to be glued back on the shaft after the shaft is roughed up a little. Disconnect the plug-in wires (note where they go on), wiggle and remove the fan motor from the oven. I used contact cement to hold the fan to the shaft. the fan motor is located right behind the control panel. You have to first remove the grill, then the control panel's screws. It's not difficult to repair. No new parts needed.
Microwave JVM 1660wbooi unit runs for two or three seconds and shuts down locks up if i unplug the uni and plug it back in it will reset and try to start again same problem if i repete this 3 or 4 tim
This is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
See
this FixYa solution. even if your model number is different.
http://www.fixya.com/support/t2330691-ge_spacesaver_jvm1650sh01_shuts_off )
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
I have an over-the-range microwave. When cooking on the stove surface, as steam hits the microwave, it will suddenly turn on. Occasionally you can reset, but usually has to be unplugged to make it work...
That will be caused by condensation affecting the controls of the microwave oven. Not a lot can be done about that except cut down on the steam maybe or wait for the temperature to rise slightly avoiding the condenation problem.
I have a GE Over the range Microwave oven, Model JVM 1540DN. It will not stop running, doesn't seem to be heating up and turntable doesn't turn. When I shut door, it turns on and won't go off. Any...
Probably a bad door switch or mount.
See
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
4helpful
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Microwave shuts off after running for five minutes
I'd be careful because you do not know what caused it to spark. How old is the microwave? Do you need a new one?
Fan and Light out on GE JVM 1650
We actually repair these for customers nationwide for only $39.95 (details here).
If you'd prefer to get a new board, they run $106.94 plus shipping, and you can order one here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
4helpful
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
