Question about Visioneer OneTouch 5800 Flatbed Scanner
One touch 5800 will not scan
I am using xp pro service pack 2 . how can i make this work
  • 6,487 Answers
You just need to run the installation CD for the scanner and it will tell you when to connect the unit and it will also install a utility on your computer that you can use for scanning..
Hope that helps..........
Posted on Jul 11, 2008
Windows xp installion does not see my hard drive on Panasonic CF-74
Just a thought but are you using XP Pro SP2 or SP3?
In my experience, only XP Service Pack 3 will see your
Hard Disk Drive, not XP Service Pack 2.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 30, 2013 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
Tip
Using Scanrouter Professional on Windows XP SP2 or Vista
Scan Router Professional software will not operate on Windows Vista computers at this time.  It can install on Windows Server 2003.
There have been issues getting Scan Router software to work with Windows XP with Service Pack 2 or higher.  While you might be able to install the software but some features may not work.
The best solution for now to get around this is to install an ftp server on your computer or server.   servu.com has a free one that you can use.
Desktop Binder software will work with Windows XP Service Pack 2 as well as Vista.  Make sure that Windows Firewall is turned off before using it.  If your behind a router with a firewall on it, you shouldn't have it enabled.
on Sep 13, 2008 | Ricoh Aficio 1035 Copier
How to install microsoft office 2007???
First, you need to upgrade your XP Pro to Service Pack 3. XP with Service pack 2 is an end-of-life product which Microsoft no longer actively supports. After you install SP3, there will be about 90-100 more Windows updates to install. They should do so automatically.
Then once you have updated Windows and scanned for viruses (since you have only SP2, there is a good change that some malware may have made it onto the system.
Now all you have to do is insert the Office 2007 DVD into your computer and the installation process should begin.
Sep 24, 2011 | Microsoft Windows XP Professional With...
My printer OCR command does not respond. The printer says it's connecting to the PC but after a short period reverts to standby.
  1. faq000559_002 When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with OCR or the Brother ControlCenter3, the text comes out as gibberish. This started after I installed Windows® XP Service Pack 2 (SP2). Why and what should I do?
  2. faq000093_012 What is MFL-Pro Suite Software?
  3. faq002613_000 When I try to scan to OCR I get an error message saying "This feature is not available because there is no OCR Software installed".
  4. faq002561_000 How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
  5. faq000562_002 When scanning to OCR from Brother Control Center3, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  6. faq000563_002 When scanning to OCR from PaperPort® SE, the following error message appears: "System error incurred in external ink module EZText.g32. The OCR server is unable to process the document". I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  7. faq002620_008 Windows® 7 Support Information
Oct 26, 2010 | Brother DCP-330C All-In-One InkJet Printer
Is Windows xp professional version 2002 service pack 2 is not xp home service pack 2. is this compatible with sql server 2005? Thanks
All Service Pack 1, 2 or 3 for XPs are for Pro & Home Edition and are not meant for other Windows Version!!
As for SQL Server 2005 you can get your Latest Updates & Service Packs @ http://support.microsoft.com/kb/913089
Hope it helps.
Oct 02, 2010 | Computers & Internet
Windows XP Pro Service Pack 2.0 not recognizing HP Scanjet 2300c
Check the cable and go to HP site and get the latest drivers
Mar 16, 2009 | HP Office Equipment & Supplies
Svchost error with zyxel p 600 series
your operating system is corrupted..........
Dec 05, 2008 | Zyxel Prestige 841 (91-004-226010) Modem
JIVA TP-5800 touchscreen problem
try cleaning the touch screen glass between the glass and the frame, if that fails, you need to replace the touchscreen glass
Jun 08, 2008 | Posiflex Jiva 5800 All-In-One...
Acer Aspire (or rather expire) Help Please !!!
if you're using the service pack 1 then that could be your problem. If you go to the microsoft website and download the service pack 2 and save it somewhere and then burn it to a disc then put it onto the computer you put XP pro onto this could rectify those issues. I hope this works for you
Mar 22, 2008 | Computers & Internet
Visioneer OneTouch 5800 Flatbed Scanner Logo
59 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
