Question about RIM BlackBerry Pearl 8100
Roller ball keeps bringing up the letter q when pressed
I cant get into any applications evertime I press the roller ball a Q comes up
  • kachou Feb 26, 2009
    My roller ball brings up the letter q and then w when pressed. Did you find a solution to this problem?
  • Anonymous Apr 24, 2009
    The same thing was happening to me but now it is worse! Now the screen goes black when I hit the roller ball!! HELP!
Thats happening to me to and when i try to write a text message the letter q or w is attached to every letter i type! please help ME!!!!!!
Posted on Aug 18, 2008
What is the best way to clean calender press rolls? I work in a Lithium ion battery plant. Our press rolls keep getting dirty.
there are some idea here, but mine is that after cleaning, you spray the rollers with a dry silicone spray like Jigaloo to stop anything sticking to them. This product will also remove sticky residue like ball point pen.
cleaning calender press rolls Google Search
Mar 23, 2017 | Drills
My one touch feirce 4.2.2 is not leting me turn on the wifi Evertime I press the the wifi switch button it still says its off What do I do
You may need to enter the advanced wi-fi settings by going to settings, touch wi-fi, then press and hold the menu key to bring up advanced wi-fi settings
Oct 31, 2014 | Computers & Internet
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
Exit full screen
It depends on what application is causing the full screen mode. Try one of the following
- hit Esc key
- Hold Alt button, while pressing Tab - this will bring up all applications that are running - you can select the desktop.
- press Alt and F3 buttons together - this will close the application that is running in full screen.
May 05, 2014 | Acer Computers & Internet
Letters keep backspacing
Try pressing the "insert" key.
May 22, 2010 | HP 386209-001 Keyboard
The roller that spins with little brushes stopped suddenly and no longer spins. I pressed the red little knob at the end of the roller but it doesn't fix the problem.
open up the roller area check to see if somthing got picked up and jammed into the rollers so that it can't work, a rock or a screw or you might even have a large amount of string or fibers wrapped around the shaft or brush keeping it from rolling
Feb 19, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I can't dial out.
The Phone application on the BlackBerry smartphone automatically converts phone numbers that include letters into the associated numbers.
To key a phone number that contains letters, press the right Shift key or the Alt key and type. The letters appear on your screen, but the BlackBerry smartphone translates them into the appropriate numbers when the phone call is made.
For example, to call 1-877-BLK-BERR (1-877-255-2377) from your BlackBerry smartphone,
  1. Open the Phone application.
  2. Type 1877.
  3. Press and hold the Alt or right Shift key and type BLKBERR.
  4. Display the menu and select Call 1877BLKBERR or press Enter. When the phone number is dialed, the letters are converted to numbers on the screen.
  5. To end the phone call, hold down the Escape key.
To return to the Home screen from any other screen, press the End key.
To lock the device, set a password. Hold the * key.
To unlock the device, press the * key. Click Unlock. Type your password.
To lock the keyboard, hold the * key.
To unlock the keyboard, press the * key
To switch the input language, hold the Alt key and press the Enter key. Continue to hold the Alt key and select a language. Release the Alt key to switch to that language.
To switch back to your original input language, press the Alt key + the Enter key.
I hope this helps
Please remember to rate this solution.
Sep 21, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
152 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
