Question about Canon NP 6035 Copier
Error code E212
I kept getting paper jams and after unjamming the last one I am now getting an error code of E212. It has told me to turn machine off & back on but has not fixed problem. Any suggestions?
  • 18 Answers
sorry I have'it only in italian
Posted on Jul 17, 2008
Its a camera home position sensor problem.clean(or)replace the sensor.
Posted on Jul 29, 2008
I had a paper jam,I unjamed it ,but the printer says that i still have a jam.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 31, 2011 | HP PSC 1210 All-In-One InkJet Printer
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and luck!
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Hp 6310 officjet all in one paper jam error
This video won't help if it's really broken, but shows you what to do for a recurring jam on the 6310.
Apr 01, 2009 | HP Officejet 6310 All-In-One InkJet...
Getting error P33 on Konica 3035
need to replace door interlock switch ms501 or the tab on the door that actuates the switch got broke off when trying to remove the jam
Mar 20, 2009 | Konica Minolta Office Equipment & Supplies
Error E3
e5 flashing in the button
Jan 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E212 Error code
"E212" Lens problem (sensor, motor)lift document feeder and look inside. is the lens stuck? when turned on it goes back and forth to check where it is
Aug 11, 2008 | Canon NP 6545 Copier
Code 200.13
Replace Sensor Input Media and it should fine The part Number 40X1223 the cost around $3.60.
Apr 24, 2008 | Lexmark X342n All-In-One Laser Printer
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
E212 is scanner home position error.remove the platen glass. Check the scanner and lense assembly.
Sep 01, 2007 | Gestetner DSc224 Copier
Canon NP 6035 Copier Logo
356 people viewed this question
old marine
old marine
