Xerox DOCUMATE 515 SIMPLEX-FLTBF W/ ADF 15PPM Printer Logo
Posted on Jan 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A line keeps showing up on the scans that's not on the documents...how do I delete the line that isn't on the original document but shows up about 1-2" in front left side of scan?
Ed Mac
Level 3:
  • Master 731 Answers
  • Posted on Jan 07, 2011
Ed Mac
Master
Level 3:
Answers
731
Questions
0
Helped
252372
Points
2239
All it takes is a minute speck on the glass when using the ADF to cause lines on a copy.
THOUROUGHLY clean the glass including the thin piece to the left of the bed if there is one.
Spray glass cleaner on a link free cloth and wipe it clean
1helpful
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
When I copy papers on my Canon imageRunner 2800 there are 2black lines in the middle of the copied paper. How do i solve this problem?
Hello mike,
You may have a fairly easy problem to fix, and that's good thing ! If the lines only appear when you use the document feeder then we can handle this. Please place a document on the platen glass and make a copy. If the copy looks good then we need to clean your "scan" glass. The scan glass is the small glass located to the left of the large platen glass. It's about 3/4" by 14",and will only cause problems when you use the automatic doc feeder.If it gets dirty then thin lines will show up. If indeed this is the problem then I have a test u can use that will help you Take a plain piece of paper. Mentally divide it into 4 squares and then simply write the numbers 1,2,3,4 on each quadrant. At the top edge of your newly formed test document place an arrow pointing away from the body of the paper, and it needs to point "UP".. Now draw an arrow on the test document that points to the left "lead " edge. Put your newly constructed test target in the document feeder and make a copy of it. Now, you KNOW how you placed the test document, so lets look at the copy. If you have lines only thru the document feeder, then look at the copy you made and notice where the lines are. Ok, now you know where the lines show up on the copy, so lets take your "test" document and compare them side by side.Once you have made this comparison, and can see where the lines show up, take the ORIGINAL test document and place it IMAGE UP (1,2,3,4) on the glass. This will point out exactly where the dirt is. By looking at the copy that has lines, and where they show up on the page, you can use the test page that is laying face up on the glass and compare the 2. BOOM !! You can look towards the small scan glass and find the dirt that is causing the lines. With your copier, IF you place a document on the glass then the scanner moves to "scan" the document. But if you use the document feeder, the scanner stays in one spot and the motion of the document moving ACROSS the scanner and is scanned like a bar code. If there is dirt on the scan glass then a line occurs instead of a "blob" as you would see if you used the platen glass.I hope this all makes sense (I tend to ramble) and I hope it helps you. You of course could have far more complex problems. But your description of the problem sounded like my remedy/idea might be just what you need. Take care and good luck. if I helped you please let "fixya" know. SPINAL
How do i delete error pages after scaanning?
I changed the settings from duplex (double sided) scanning to simplex (single sided) scanning under the settings tab in the scansnap organiser. this was ok since i had all one-sided documents to scan. you would need to reverse this settings change anytime you have a double-sided document to scan.
1helpful
Line down the scanned document on a HP LAser Jet 3050
If you are scanning using the Auto Document Feeder be sure to clean the glass where the documents get scanned. A small speck will cause a line down the page. On HP there is often a narrow strip of glass on the left side of the platen glass.
5helpful
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
1helpful
2answers
Printer/Scanner Problems
Does the line show up on PRINTS FROM YOUR COMPUTER also, or only when SCANNING A DOCUMENT? If the line is only from scanned documents, the SCAN GLASS has something stuck on it. The SCAN GLASS is a GLASS **** located under the ORIGINAL FEEDER. It is NOT the plate of glass you place the original on . Look UNDER the original feeder for a scrap of paper stuck in the optical path of the GLASS ****, and remove the scrap, or CLEAN THE SCAN GLASS IF CORRECTION FLUID, INK, ETC ARE STUCK ON IT. If the line shows up on ALL prints, your CHARGE CLEANING SLIDER located in the IMAGING (DRUM) UNIT must be slid all the way to one end of the charger, OR IT WILL CAUSE A BLACK LINE ON ALL PRINTS. Otherwise, the IMAGING UNIT may need to be cleaned or replaced. Toner smudges on the drum would indicate need for cleaning or replacement.
2helpful
Lines showing up on document after scanned
Do you have lines, too when scanning a document?
In this case the scanner glas needs cleaning. Use a soft cloth and some glass cleaning solution and wipe the scanner glass. The lines should disappear.
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
