Sony kp_51ws500 red light blinks 6 times
  • Anonymous Oct 09, 2008
    sony kp-fx43m31 all so red light flashes 6 times
Where can i find replacement lamps for this tv
Posted on Sep 26, 2008
SONYmodel # KP51WS500 tv work for 45 minutes then blankout with a blanking red light
How many times does the light blink in between pauses? Let me know and I will assist the blinking is an error code.
Aug 09, 2011 | Sony KP-51WS500 51" Rear Projection...
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
I'm getting 6 blinking lights on the dashboard of my Sony KP-51WS500 and no picture
there is a voltage regulator locATED next to the flyback transformer this will fix ur proble normal repai is about $250
Apr 12, 2010 | Sony KP-51WS500 51" Rear Projection...
KP-51WS500 when on it blinked 4 times and has redscreen
Typically if you have a all Red Screen it is caused by either the Red CRT being shorted or The Red CRT Driver Board being bad.
Jul 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 tv went red screen on me it has 4 blue lines going across also has blinks 6 times.. what do you think this might be..
Off hand I would con dim the Red and Blue CRT"s. If you were to replace two of them I would also do the Green CRT as well. The cost of just doing two of them is way too expensive in my opinion and you would be better served to replace the set instead of investing the amount of money needed in a 6-8 yr. old set.
Hope this helps,
Skyassoc
Jul 15, 2009 | Sony KP-51WS500 51" Rear Projection...
KP-51WS500 Flashing 6 Times
Well, it's DEFINITELY the High Voltage power supply is DEAD! Won't start up...or goes into OVERVOLTAGE SHUTDOWN....
Most of the time it's overvoltage problems...
The KEY to knowing which one is actually occurring is the amount of time it takes before the 6 blinks occur...
A DEAD HV circuit takes a lot of time, while the OVERVOLTAGE will take less than 40 seconds for it to register the 6 blink code....
In this case (overvoltage) replacing the HV oscillator/regulator IC is mandatory...
A dead HV circuit could be anything in the HV circuit, from the Regulator IC to the HV splitter...
It's really wiser to consult a TV technician on this....
Mar 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
5 Blinks, no picture
Power supply (start up) failure.
Mar 04, 2008 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
Electro Med Services...
