Sony kp_51ws500 light blinking 6 times - Televison & Video
  • smokingjoe04 Jul 11, 2008
    could you send me the link ty
  • 8,617 Answers
Thats the error code for Overcurrent or over voltage protection shutdown. Which means the +5 v line is either shorted or overloaded on the A or B boards. I usually recommend that you replace the A board first as thats usually the cause, then if that doesnt do it the b Borad will need replacement. I have a link that has new Circuit boards available for your model if you would like the link.
Posted on Jul 11, 2008
  • Sonny Berry
    Sonny Berry Jul 11, 2008
    Here is the link, just leave them a email with your model and what your symptoms are and they will respond quickly, they dont always list the new Circuit boards, But they have every one that I have ever needed.
    http://servicemanuals.vstore.ca/
tvtek
  • 1284 Answers
SOURCE: sony model kp-51ws500
You have all three projection tubes that are failing. This was a common issue for this year. Depending on serial number 2 of the 3 CRT's (green and blue) are no longer available. They will have to be pulled and rebuilt.
Posted on Feb 23, 2007
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
ginko
  • 19396 Answers
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Posted on Dec 01, 2008
  • 41 Answers
SOURCE: My Sony Color Rear Video Projector Model # KP-51WS500
I think Jean got this one right. This sounds just like the problem that this site will help you fix.
Posted on Mar 13, 2009
  • 668 Answers
SOURCE: Sony KP-51WS500 tv went red screen on me
Off hand I would con dim the Red and Blue CRT"s. If you were to replace two of them I would also do the Green CRT as well. The cost of just doing two of them is way too expensive in my opinion and you would be better served to replace the set instead of investing the amount of money needed in a 6-8 yr. old set.
Hope this helps,
Skyassoc
Posted on Jul 15, 2009
I'm getting 6 blinking lights on the dashboard of my Sony KP-51WS500 and no picture
there is a voltage regulator locATED next to the flyback transformer this will fix ur proble normal repai is about $250
Apr 12, 2010 | Sony KP-51WS500 51" Rear Projection...
KP-51WS500 when on it blinked 4 times and has redscreen
Typically if you have a all Red Screen it is caused by either the Red CRT being shorted or The Red CRT Driver Board being bad.
Jul 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 tv went red screen on me it has 4 blue lines going across also has blinks 6 times.. what do you think this might be..
Hope this helps,
Skyassoc
Jul 15, 2009 | Sony KP-51WS500 51" Rear Projection...
TV will not come on. TV standby light blinks nine
You need to call a Sony service center for this problem. It will cost you less in the long run.
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
KP-51WS500 Flashing 6 Times
Well, it's DEFINITELY the High Voltage power supply is DEAD! Won't start up...or goes into OVERVOLTAGE SHUTDOWN....
Most of the time it's overvoltage problems...
The KEY to knowing which one is actually occurring is the amount of time it takes before the 6 blinks occur...
A DEAD HV circuit takes a lot of time, while the OVERVOLTAGE will take less than 40 seconds for it to register the 6 blink code....
In this case (overvoltage) replacing the HV oscillator/regulator IC is mandatory...
A dead HV circuit could be anything in the HV circuit, from the Regulator IC to the HV splitter...
It's really wiser to consult a TV technician on this....
Mar 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony kp 51ws500 Screen fades to blue
the tuner is going out on it or has gone out and yes its fixable
Aug 29, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 Blinks/Flashes 6 Times
nspect the bottom of these boards for cold solder joints with a magnifier & resolder suspect pins, also check the capacitors on the board, if they are little silver smd type look for yellowish liquid to be present around one or several of them, you need to replace, either of the above could be your solution.
Jul 20, 2007 | Sony KP-51WS500 51" Rear Projection...
2002 sony projection screen tv kp-51ws500
the set has a bad tube Don't spend any more money on it
Mar 03, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
