I accidentally knocked one of the capaictors off the inside of my PC. It is still working, but have I caused any damage and will I need to replace the motherboard?
  • 50 Answers
If it aint broke dont fix it, the pc will answer that for you if it keeps working fine you lucked out if you start having problems you know why and will have to replace the mobo
Posted on Jul 12, 2008
Tata suspension damage
You haven't provided enough information to even begin to provide a diagnosis of the knocking but from your tyre description it is clear the vehicle should have a thorough safety inspection and any unacceptable parts replaced and then finish with an alignment check and adjust.
Tyres wearing on the inside shoulders would indicate the front wheels are toeing out too much (or the camber angle is wrong) and a life of less than 1000km indicates the problem is severe. While maladjustment is possible, this sort of thing is usually caused by accidental damage or the serious wear of one or more steering or suspension components.
Aug 10, 2016 | Tata Cars & Trucks
After i plugged external speakers into my laptop, the laptops speakers stopped working. I've tried driver updates rollbacks re installs and pretty much everything else i can think of, being a mildly
The laptop speakers should only be cut out when the externals are plugged in. This is done by a little switch inside the jack. If it will not switch back and the external speakers still work fine then I would say that is definitely the problem. There is not much you can do if that is stuck. All the switch really looks like is a strip of metal that is like a spring. When you push the plug in it pushes this to the side and disconnects the internal speakers. The jack is mounted on the main board so you would have to locate the proper one and solder it on or replace the main board. Short of going that far I would see if inserting a jack a few times will get it to spring back. If there has been any spills on the laptop or it is gummed up inside you can use proper electronics connector cleaner. This is risky as it can damage the plastics but doesn't take much at all to work. I would look inside the plug and see if you can see debris or gunk. I'd also try knocking it. This is literally knocking around the switch like you are knocking on a door. You don't want to hit it really hard but just a few short sharp knocks will loosen things up with out causing damage. If you knock like the landlord looking for rent money then it might ;-]
Nov 22, 2011 | Sony Computers & Internet
My laptop's hinge is broken but the connectivity is still on. Can I replace only the outer case? If so where and how much would it cost?
It is not the outer case only, the HP/ Compaq laptops outer case is very thin fiber, from inside you've a metal hinge and bar holding it. You can take it to a local store to get it repaired. I would suggest if you have HP Accidental Damage Protection (ADP), you should call HP. They will replace or repair all accidental damages.
Regards,
Shrey
Jun 07, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
My iomega external hard drive just beeps when ever i turn it on. How can I fix this?
ummm, i fixed my problem i had with a iomega 500gb external hard drive, it was beeping at me also, so what i did was i knocked it on its side, switched it off, by its own panel, then switched it back on, it came back into life and was recognised again!!
so try it with yours!
I think what what happens is, when you accidentally drop it, or knock it from time time(accidentally), the needle inside the hard drive goes out of place, and the hard drive will beep, or something to that effect. knocking the case itself again, might fix the problem, or maybe not, thats if the hard drive itself is more severely/inherentally faulty.
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hi there i knocked my computer over the other day and now it wont link to the screen, plus keyboard and mouse dont work, i've looked inside dusted and stuff but cant see much wrong a few loose wires e.g p7...
Please don't misunderstand but maybe you accidentally touch someting inside the system while cleaning it that caused for the computer not to work properly. Be careful in cleaning our computer specially inside. Replug all the links needed because the computer may reconfigurate it again before it will work. If it won't work however, please contact you Hardware IT Technician.
Mar 22, 2011 | Computers & Internet
I teach fourth grade. One of my students tripped and knocked the entire printer on the floor (I've had it one week :-( ) The carriage complete w/printer carriage came loose in the machine. I eventually...
If it's only one week old, its "warranty" may cover "accidental" damage. Take it back to where you bought it, and get them to trouble-shoot, and/or fix, and/or replace it.
Apr 23, 2010 | Computers & Internet
The power went out today. Once the power was restored, the green (Timer) light simply keeps flashing and the TV wont turn back on. None of the buttons on the front of the TV work nor does the remote. I...
There are 7 capacitors that need replacing in you digital module, it is located on the left hand side facing the back of the set. After opening the module there is a small power board inside, replace all 1000uf 16volt capaictors with 680uf 16volt capaictors. After replacing them there will be a small green led on the board that lights inside the digital unit. it will flash then go steady if all is ok with the set after replacing these capacitors. After this is done the power light up front will blink about 30 secs then go off. Turn on the television and happy viewing...
Please leave comment...
Oct 08, 2009 | Televison & Video
The cat knocked over the tv.. the screen looks all white and shattered.. can that be fixed or replaced it looks like some one punched it,,
Unfortunatly the screen has been damaged beyond repair & will need to be replaced. This can cost almost as much as a new TV so it would probably be more economical to buy a new one. If you have insurance you could try to make a claim for accidental damage to recover some costs.
Sep 07, 2009 | Insignia LCDTV26 26 in. Television
Power surge knocked out my laptop. Now it only starts up for 10 seconds and shuts off again. How can I replace the motherboard?
The processor is overheating causing auto shut down to prevent damage(further). Get the heat sink & if required apply fresh heat conducting paste between the processor & heatsink(if the fan is still working). Also the power supply inside the PC might not be delivering the correct voltage(3 different voltages), which will require relacement..................sodeep
May 11, 2009 | Computers & Internet
Power and charging failure
I suspected the damage cause is inside. It might have some spark inside that affect the wires.
I you want to replace your power adapter send it to the service center near you. Just tell them that its not working. (If under wrranty replacing of parts is free of charge). If you tell them that you accidentally broke it, it replacement is not free of charge due to user fault.
Apr 06, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
