Question about LG Washing Machines
How do I get the rear ring clamp with the spring back on the front door seal. I took it of ok and have changed the seal but I cant seem to get the spring to strentch enough Thanks Mark LG wd 8013f front loader
  • 5,911 Answers
It takes another set of hands to stretch and hold the spring in place at the 3 and 9 o'clock positions. With the spring held in place in this manner, pull the remaining portion of the spring straight down at the 6 o'clock position with one hand and hold it while working the rest of the spring into the groove with the other hand. This is the toughest part of replacing these door seals, but it works better with two people. Please let me know if you need further assistance. I hope this helps you.
Posted on Jul 11, 2008
I have the Samsung WF448AAP/XAA clothes washer. The large retainer ring for the front door seal came off somehow. Its a heavy gauge steel wire loop with a spring assembly integrated into the loop. How...
You need to reinsert the door seal back onto the door frame and replace the spring clamp back on. The spring is fairly heavy duty and it will require some muscle to get it back on. Good luck
Jun 17, 2011 | Samsung WF448AAP Front Load Washer
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Wire clamp that holds seal
The wire clamp that holds the seal for the tub just inside the door has popped off this video will show you how to put it back on
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 16, 2009 | Bosch Washing Machines
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
How to change door seal on hotpoint m w a 60 washing m/c
you need to remove the outer retaining ring which is a wire around the lip of the seal typically joined with a spring., using a small screwdriver.
the inner retainer is held together by a ratchet type assembly. prise one end of the wire by twisting the folded end of the wire out of the groove til it comes free.
replace the seal. fit the inner retainer together using some long nose pliers, prefferably bent-nosed. the outer retainer with a screwdriver.
Feb 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Door seal
switch off your power to the washer pull-out so you can undo the screws for the lid take the lid off now open your door there should a clamp surrounding your door seal you may not be able to see it but it is there undo it now look inside your washer to the inside at the back part of your door seal there will be a clamp this should either be a spring clamp or a screw clamp undo this clamp door seal with pull off now reverse the order of how you took your door seal out problem solved it is not too hard to do once you have done it you will find any washer door seal easy to replace trust me done thousands m8
Aug 13, 2007 | Bosch Classixx WVF 2402 Front Load...
KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Dec 20, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
150 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
