Question about Goodman Heating & Cooling
How do you turn on an air conditioner I have ensured the power swtich was on outside, what more do I have to do?
  • 828 Answers
Make sure the power is on to the air handler or furnace. Control voltage comes from there. Also check the circuit breaker in your main power panel and make sure it is on for the air conditioner.
Posted on Jul 11, 2008
My mini split system had an E2 code...replaced indoor pipe sensor...indoor unit works but outside unit does not...no other error codes, just motor not working outside
Check the outdoor unit to ensure power is available to it, and the contactor is closing on a call for cool 24-28 volt is present at the contactor coil to activate it.
Aug 24, 2013 | Continental Electric CE-AC7581 Ductless...
Fan runs, but compressor does not engage. Therefore, no cool air.
Need more info is this a split air conditioning unit are you referring to the condenser (outside part)? Assuming you are check for burnt out contacts, FIRST ENSURE your power is off!!. What tools do you have?
Aug 13, 2011 | Heating & Cooling
Portable air conditioner not cooling
Ensure your Portable Air Conditioner is sized properly for the room it is in.
A good rule of thumb is 12,000 BTUs for 400 square feet. If the room you are attempting to cool is too large, then the cooling effectiveness will change.
Also ensure that the air conditioner is properly vented outside of the room.
May 21, 2011 | Heating & Cooling
How do I know if compressor of my house air conditioner is turning on when I start my air conditioner? When I start my air conditioner the fan outside the house turns on, the air is blowing from the vents...
if the compressor is starting there will be a very small dimming in the house lights,if you go outside to the unit and start it from the outside disconnect when the compressor starts you will hear a whine type noise coming from the outside condenser unit that is the hermetic compressor motor operating,no cold air can be a number of issues,low on refrigerant(not likely on the new sealed systems) a bad motor start/run capacitor(quite likely) a bad contactor on the outside unit that supplies power to the compressor,one leg of the 240volts that supplies the compressor power,the fan will run on 120 volts,but the compressor needs 240 volts check the fuses.breaker in the power panel
Apr 02, 2010 | Heating & Cooling
The fan outside will not turn on
Check to ensure your getting power to the motor. If you are, the condenser fan motor is probably bad and will need to be replaced.
Jun 26, 2009 | Heating & Cooling
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Air conditioner not working
the outside condesor unit is not coming on for a number of possible reasons. First check your breakers for a tripped breaker, even if they appear on, turn the ac breakers off and then turn them back on. if after this, turn on the thermostat, outside you should here the contact switch on the condensor unit humming. if still no power, check for any breaks on your wires going in from the house, still nothing give a call back
Jun 24, 2008 | Ruud UAKA030 Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
