Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Bottom drawer floods up
Have cleaned the screen but not sure where to find this hose that is on the instructions
also the light on the switch is bright red i know that has something to do with salt issue?
Check the lid seals are sealing correctly.
Posted on Jul 11, 2008
Model 920 shows U1 then leaks then goes to F1
Hi
Error code U1 means that the dishwasher might be taking longer time then required to fill the water and water is not draining properly as something might be blocking the drain pump assembly due to which the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. Also check the water supply and spray arm. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that it is fine. Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now' you'll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Fisher and Paykel Dishwashers
The dishwasher would beep and f1 would appear. Ty
Hi
Daniel
Aug 03, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher started beeping and had F1 on the display. What does this mean?
Hi
Daniel
Jul 19, 2011 | Fisher and Paykel Dishwashers
F1 signal
Hi
Daniel
Apr 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My the drain hose on my dishwasher got kinked and I fixed it but I keep getting a F1 error. I dried out the pan underneath. how do I reset the flood switch?
Hi
Daniel
Mar 19, 2011 | Fisher DD603B / DD603W / DD603H Dishwasher
Both drawers on our dishwasher will start by it self and will display "F1". In our user guide - it tells us "flood switch has been activated". How can I fix it?
Hi
Jan 31, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 symbol flashing
Hello, this video explains how to repair this issue.
http://www.appliancerepairlesson.com
Dec 13, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and Paykel f1
Hi
Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now’ you’ll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry.
Hope this helps...
Daniel
Aug 13, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
F1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
May 15, 2010 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
44 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
