Question about Whirlpool LER5636P Electric Dryer
Kenmore Thermostat On the Hi Limit themostat I am getting continuty for red to red white conections through the themostat but no continutity for the puple contection terminals through the themostat. Will this mean the thermostat is bad and will cause the dryer not to turn on.
  • 417 Answers
order or study the wiring diagram, could be a hi/lo heat setting circuit, the dryer should spin no matter what heat problem, jump the door switch
J
Posted on Jul 11, 2008
Need help understanding how to wire a new programmeable thermostat. I currently have a White Rodgers 1F73 model (non-programmeable) connected. I am confused with the instructions on how to connect the...
the black wire is your common wire, you need to program your thermostat, in the advance mode, to tell the t-stat if your heat pump reversing valve is energized on cooling or heating, is the orange wire connected to your t-stat.= w2/o/b
Dec 20, 2014 | Honeywell Heating & Cooling
The dryer themostat went out and need it quickley
Try "Sears parts" or "Amazon" or "e-bay" as a source for the part you need.
Be blessed.
Feb 22, 2013 | Kenmore 3389946 279769 Thermostat /...
Kenmore High limit switch
if the high limit is blown the dryer will not run.It can be checked for continutity.you can jump the two wires together to see if the dryer runs.Do not leave it jumped out permently just to test it.If this is bad replace and clean the vent the entire vent.
Sep 19, 2012 | Kenmore 64892 Electric Dryer
Drier works but doesn't get hot heating coils look ok.there is a white thing with two wires going to it that has continuity.there is also a thing that looks like a black circle with 2 big red wires and...
These 2 things your describing are they on the housing where the heat element or the housing where the lint filter is??
i suspect they are the housing where the lint filter goes and the white on is the thermal fuse and it is good because it has contunuty on it (if it were bad the dryer would not start) the one w/4 wires is the cycling thermostat annd it too is good...the red wires will have continuty and the purple wires will not.
NOW THEN WHAT YOU NEED TO CHECK is the heat element for continuty AND both of the thermostat on the housing where the element fits BOTH t-stats on that housing should have continuty.
GENE
Sep 06, 2011 | Roper Dryers
Kenmore elite gas dryer won't heat.I tested thermal fuse, high limit thermostat, thermistor and gas valve. All within spec or have continuity.
Hello Chuck,
In addation to what you have checked here is a list of what else to check
Flame switch...black box on burner tube...check for continuty
Ignitor...check for 120 vac too it
Timer/control board heat relay..on models w/timer check for contunity in heat circuit on timer. ON models w/control check that heat relay on board is closing and has continuty
Motor switch..check that heat circuit is closed and has continuty when motor is running and motor switch has closed for heat circuit(the start winding switch on motor will be open when running)
WARNING..WHEN PLUGGED IN FLAME SWITCH WILL BE LIVE ALL THE TIME AND SHOCK YOU WHEN TOUCHING..BE SURE TO DISCONNECT POWER BEFORE CHECKING
Gene
Aug 09, 2011 | Kenmore Dryers
Kenmore Dryer Model 110.74612200 won't heat ... drum spins and blows air but doesn't heat up
Possibly sounds like your high limit thermostat which is normally the problem with all dryers. When they go bad it will cut the power from your heater. The high limit thermostat is located on the top left of the heater core which is the smallist thermostat on the unit with two red wires running to it one solid red and one solid red with a white stripe. Need a volt meter with a buzzer on it to see if the high limit thermostat is bad just set your volt meter to buzzer or bell symbol normally has a bell on it. Take the positive and negative leads to the thermostat and see if it makes a noise if it does then the thermostat is good if it dosnt make a noise then it is bad (replace it) then if the high limit thermostat is good move down to the heater and test the same way if the heater dosnt make a noise after putting test probes on it your heater is bad continue to test the different thermostats (should be 3 thermostats) (the white rectangle with the two blue wires going to it is a thermo-fuse no need to test it) if they all work and including the heater it is possibly a power problem with your cord or jack and if that is good it is a bad timer that will have to be replaced. You can purchase all these parts from a Appliance Parts House in your area and if you feel unsure on how to test or replace the parts call a qualified technician to come out to your home.
Jan 04, 2011 | Kenmore Dryers
Kenmore Model# 90412 Item # 41783042300
The Thermal Cut-Out (TCO), Heating Element or Hi-Limit Thermostat are all logical choices. If the dryer had an overcurrent condition that caused your terminal block to burn, you may have more than one problem. The component readings should be as follows:
Thermal Cut-Out - (0 ohms)
Hi-Limit Thermostat - (0 ohms)
Heating Element - (9-13 ohms)
If the either the TCO or Hi-Limit Thermostat are found to be defective, you need to replace BOTH of them at the same time. Failure to do so may result in premature failure of any parts you do replace. These components are commonly sold as a set for this reason.
NOTE: Make sure you take any resistance checks with the dryer UNPLUGGED and any components under test should be isolated (meaning disconnect any wires). This ensures you don't have any false readings due to parallel resistance paths.
The TCO and Hi-Limit Thermostat will be located on the outside of the heater box where the heating element is located. The TCO will be the component at the opposite end of the heating element terminals, while the Hi-Limit Thermostat will be adjacent to the heating element terminals.
Also, I know an electrician wired everything up for you, but I would still recommend you double check the terminations at the terminal block. The wires should be connected as follows:
Match these corresponding colors at the terminal block -
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN (or Bare Copper) - Ground. Needs to be connected to the ground lug on the equipment cabinet. Ground and Neutral DO NOT get terminated together in a 4-wire configuration. Make sure these two wires are isolated from each other.
NOTE: If the wires are not color coded, the outer two terminals are the hot leads. The center terminal is your neutral.
If you have questions, please post back with your complete model number, so that I may be able to provide you with better assistance. I hope this helps you.
Oct 15, 2009 | Dryers
Dryer heat not working not sure how to check the heat element to see if the coils are bad or just the: thermal fuse, thermostat limit switch.
to check to see if coils are bad you need to do a continuty check. Remove electrical connections on the ends of the drier element. Get your ohm meter and ohm the element. If your element is good you'll get a signal, no signal , bad element. If the element is good then the problem is more than likely the hi limit switch. Good luck on repairs
Dave
Sep 01, 2009 | Dryers
Kenmore electric dryer mdl#110 67832791 no heat bought a element 100 dollars w/overnight shipping did not fix problem !!! charged credit card 15 for advice! themostats high limit stat...
check the white fuse on the blower can
make sure you are getting 240 volts
the safty fuse and tstats you said you checked
only other thing is the timer
Apr 18, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
81 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
