Question about Kenwood Car Audio & Video
Kenwood stereo 6 Stack stereo on boat. Doesn't receive AM. FM ok. Doesn't seem to be sensitive to whether the aerial is plugged in or not.
  • oceans Jul 11, 2008
    Very difficult to get to the soldered connection pins on the socket in the PC board, but the solder looks sound. Tried wiggling the cable in the socket without any effect.
    I may have to give up.
  • oceans Jul 12, 2008
    No antenna power output connection on unit. I think the fault is with the antenna socket but I am unable to get in to the CB to fix it.
    A.
  • 6,487 Answers
Some radios have an output for a power antenna, Turn the radio on and the antenna goes up. If a radio had such a signal,couldn't it power the antenna amplifier?
Hope that helps.............
Posted on Jul 11, 2008
  • 2,427 Answers
There could be a problem with the port the aerial is plugging into, what you can do is examine the ports for defects ,
1.) open it up
2.) look at the port, there should be solder holding it in place as well as solder holting the connection pins in place.
3.) resolder the pins
4.) turn it back on taking care not to touch the circutis
5.) gently plug back in the antenna and shake it slightly to ensure iys working.
6.) turn it of disconect it and reassemble it.
That should work if not let us know and we can be of further assistance. Do Not Rate Until YOu Are satisfied with your experts Responce or the Problem has been resolved
Regards Dark
  • Rishi Roshan Ali Jul 12, 2008
    Then there is a problem with the circuits itself, Have you any experience with circuits then give the aantenna amplifier a go, if not take it to a technician
    State the make and model you have i can google a service manual for you or if you wish you can try googling it your self,
    If you dont have any experience in this I'd suggest you get a technician to do it for you, the choice is yours, i can help get you the service manual and attempt to answer your How to's to the best of my ability but keep in mind I am not present there with you,, But i will do the best i can if you choose to attempt the repairs your self.., Please supply the exact make and model
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
Where is the aerial input located on this item
Look for 2 small shiny metal screws on back, fm aerial is usually a T wire with couple forks which go under the shiny metal screws.
Nov 16, 2013 | Panasonic Technics Sa Gx100 Amplifier...
My Kenwood Radio (New) for my boat doesn't tune properly on FM. For example, it only tunes to 94,1 or 94,3 but not to 94,2 It is just ,1 digit off the frequency on most stations. Tried it on manua
Kenwood receivers are usually tuned for their intended destination country, hence the frequency "stepping" of the tuners may differ between countries.
Was this receiver originally intended for your country's frequency? If yes, then contact Kenwood customer service for further advice.
If not, contact your local Kenwood service agent and ask whether the frequency stepping can be reprogrammed.
Feb 20, 2013 | Kenwood Car Audio & Video
Why can't I receive AM or FM radio
check the aerial is plugged in properly at the back of the radio
Mar 12, 2011 | Jensen MCDA1 AM/FM/MP3/ Stereo with...
Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Apr 06, 2010 | Kenwood KR-V7080 Receiver
My battery was disconnected for a new starter motor to be fitted - now it won't tune in. CD works but radio just hisses? I've checked aerial connections which seem OK. Radio lights up and looks like it...
Somehow your antenna has become disconnected. Check the back of the stereo and look at the ANT connection. Remove it and test continuity from the center to the outside antenna. Chassis is ground and most likely will not have a problem.
Jul 05, 2009 | JVC AM FM CD DET FACE CAR STEREO
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Fitting a Kenwood car stereo to a 2003 Toyota Hilux ute, all works well until aerial lead plugged in, then immediately the fuse blows that feeds park lights, dash lights, instruments etc. Car stereo works...
The vehicle chassis ground or negative is opposite to the stereo. The aerial is vehicle chassis ground (earth), when touched to stereo results in direct short. If the Hilux is positive ( + ) chassis (earth) and the stereo is negaitive ( - ) ground, there is the short. If this is the problem, either replace with a compatable stereo or compatable vehicle.
Dec 27, 2008 | Car Audio & Video
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Car Audio & Video Logo
56 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
