Question about IBM ThinkPad T30 2366 Notebook
IBM T30 - power issues
I have an IBM T30 laptop that has some strange symptoms I've not run across before. Any assistance is appreciated. Here are the symptoms:
1. Laptop runs on AC or battery power, but does not recognize the AC adapter.
2. Laptop will run without AC adapter (on battery).
3. Laptop will run without battery (on AC). Still does not recognize the AC adapter as being plugged in. Shows battery icon on tray and in power management.
4. When running on battery power, the unit shows no ill effects when you plug in the AC adapter. However, if you subsequently unplug the AC adapter, the computer shuts off, even with a full charge on the battery.
5. The battery icon does not show that the battery is charging, but it is, and has been confirmed by plugging it into another laptop of the same model.
Steps I have taken without success:
1. Replaced the battery with a new one.
2. Substituted in another AC adapter.
3. Updated BIOS to the newest revision.
4. Attempted to update the embedded controller, but due to the fact the system does not recognize the AC adapter, it will not allow the update to occur. (In IBM's infinite wisdom, they put this in as a failsafe so the system wouldn't shut off during the upgrade)
The only thing I can think of that I haven't tried at this point is replacing the CMOS, but the system doesn't show any of the symptoms normally associated with a CMOS failure.
  • matthew231 Nov 30, 2008
    same as previously mentioned not recog ac adaptor
    Problem Solver:
  • 5 Answers
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Posted on Jul 11, 2008
  • jeffbeckspe Jul 11, 2008
    If one of the above does not work. It may be the ac adapter plug in on your laptop is bad , loose,broken,lead short. and needs to be replaced.
No sound
Please click on the link below to download the audio driver of your laptop.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
Jun 24, 2011 | IBM ThinkPad T30 2366 Notebook
Hello sir/ madam where i need to download ibm thinkpad t30 video drivers
Drivers for IBM T30 can be download from IBM Official Support
Select the Video Drivers according to the Operating System you have on your laptop
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
Jan 04, 2011 | IBM ThinkPad T30 2366 Notebook
My IBM T30 Think pad lap-top is stuck in power save mode.The battery is still charging fine,but the whole screen is black with no image when i turn it on.However when i switch it on,all the leds light up...
Try to power drain the motherboard.
please follow this steps:
take out the battery
unplug the power adapter
press and hold power button for 30 secs
put everything back in
power on the computer
if issue is not resolved. There could be a possibility that this is LCD problem.
May 21, 2010 | IBM ThinkPad T30 2366 Notebook
No sound from my IBM Laptop
Hi, I suggest you to uninstall the sound driver you ve got from control panel, add/remove programs. Then download the uptodate driver from IBM support page: Reinstall it, should work, if not then you might consider to have an hardware issue, in this case I suggest you to contact the IBM support if still under warranty to get a replacement, hardware failure are covered by warranty terms. Thanks and have a nice day J-
Mar 01, 2010 | IBM ThinkPad T30 2366 Notebook
How do I charge my battery on my t30 lap top battery
You normally need a compatible Power Supply plugged into the Laptop from the mains. Without this the battery will go flat. If you do not have one a good place to look is Ebay, or the like simply put in the model name of your laptop and the words Power Supply.
EG: IBM ThinkPad T30 Power Supply.
Feb 03, 2010 | IBM 11P8273 for Thinkpad 14.1" Flat Panel...
T30 cannot connect to projector/external monitor on windows 7.
You can connect your computer to a projector to give a presentation on a large screen.First make sure the projector is turned on, and then plug the display cable from the projector into a video port on your computer.
Then press Win Key+P or run DisplaySwitch.exe and choose your preferred display.
Note:1.You can use this same procedure to connect your computer to a monitor
2.This will have no effect if you’ve only one display connected
Nov 09, 2009 | IBM ThinkPad T30 2366 Notebook
When i turn it on only the battery light works what should i do and what is the problem
I just experienced the same issue and found some excellent advice when facing this symptom. Search FixYa for "Ibm t30 post beep error 1 3 3 1." It could be one of your memory boards or the memory socket itself. I pulled out the hard disk, CD ROM, and two memory boards (there is good info on the Lenovo site on how to safely do all this) . I then added back one memory board, applied power, and voila the T30 came to life. I then added the hard disk, CD ROM, and rebooted after adding each device. After adding back the second memory board, I experienced the original problem. So this memory board or the memory socket appears to be the culprit.
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
T30 motherboard problem
press f8 on boot up. select safe mode
Go start>run
type msconfig
hide all micosoft items in services and deselect the remoaining
Also deselect any "dghdfg" looking items from startup
Install CCleaner & run
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
T30 does not turn is blank
This could be a couple of different things. First, remove the battery and start with AC power only. Sometime batteries will malfunction and cause this. Second, remove the memory and try starting with one chip in, then change out the chips and try. And third, this could be that the hard drive is begging to fail. If the hard drive doesn't initialize and the machine can't read it, then it will appear to be on without running. Usually it's with the small electric motor in the drive. Next time it doesn't start, listen to see if you can hear the drive spinning, if you can't, then it's the hard drive. Run through these one at a time, if you find that one helps then you don't need to follow on down the list.
Jul 18, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
359 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
