Question about Sharp AR-5316 Advanced Digital Imager Copier
AR-M205 U2-40 Error Message is indicated
I tried a second toner cartridge with the same results. Tried the old cartridge and low toner LED is indicated. Reseat the back connector and cleaned the connector still the same issue.
What else can be done? What is the part number for the back conector?
Can the code be reset? If yes, how?
Thank you for your help.
  • Sharp Master
  • 2,794 Answers
It appears that there is a memory problem that appears to be corrupted. It should be repaired by a technician.
Posted on Jul 13, 2008
  • Tim Babcock
    Tim Babcock Jul 14, 2008
    Before you place a service call. Unplug the power cord. Wait 30 seconds and turn it back on. Resetting the power can make the corruption go away.
    If you still get the error code after that, then place a service call.
F2-04 error on sharp machine AR-M205
The code you have indicates there is a problem with the communication chip within the toner cartridge. The only solution I can think of is to replace the toner cartridge with a new one. Make sure you turn off the machine first, then swap out the toner cartridge then power back on.
Hope this helps.
Jan 30, 2017 | Sharp Office Equipment & Supplies
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Sharp ar-m205 f2 error code blinking instantly and device doesn't go to service menu
F2 04 Improper cartridge (destination error, life cycle error).
Try to put back the old cartridge , see if F2 dissapears, or try to put in a new one.
the toner cartridge seems to be the problem.
Nov 05, 2010 | Sharp AR-M205 Copier
Printer displaying an error message: 2U
There is a long list here for the U2 code so if you let me know I will tell you what it means..
Again what is the Last part of the Code?
If it is U2-40 code, it is a Crum Chip, Take the toner out clean the end of the toner cartridge, there is a chip, a small plastic connection piece with bronze/silver wire on it.
Or replace the toner cartridge.
You will also need to clear the code with simulation 16.
Turning the machine off might work but, not usually.
Oct 28, 2008 | Sharp AR-M205 Copier
Solution for copier
Your copier does not like your toner cartridge. Make absolutely sure you have the proper cartridge AR-202MT. Or, the countdown chip in your cartridge has reached zero or is malfunctioning. In any case, try a new toner cartridge.
Apr 05, 2008 | Sharp AR-M205 Copier
F2 on appears the Display
Try reinstalling the toner unit. Then try replacing the toner. CRUM error. CRUM is a small chip on the Toner cartridge.
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
