Question about Kenmore 60654 Microwave Oven
My Microwave displays the letter 'd' on the front panel and does not heat
What does the letter 'd' mean when it is displayed on the panel over on the far right?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave
Since it's under warranty, they will replace or repair it at their choice, and if they replace it, it will be the same model or a "like model".
I'd ask them about it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: display panel works but no heat, no fan, turn table doesn't turn
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 12, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Display panel is scrambled on my Dacor DMT2420 microwave.
There are two options for this model:
- You can order our exclusive modified control unit with our proprietary upgrades for $135, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $40.
For details, see: http://www.microwavedisplay.com/exchange.htm
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
Posted on Jan 29, 2009
  • 408 Answers
SOURCE: MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Posted on Mar 10, 2009
taran_2005
  • 10515 Answers
SOURCE: MICROWAVE DOES NOT HEAT.
The F-9 error code indicates a defective control board, inverter or line voltage too high.
Repair or Replace them.
Thanks.
Panasonic microwave default code H95? What does this mean?
The magnetron has failed. Likely the inverter needs to be replaced as well. Best to just replace the entire microwave oven with a new one.
May 06, 2015 | Panasonic Microwave Ovens
Display lite not working
Your display can be economically repaired.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | Frigidaire Microwave Control Board -...
How do I increase the intensity of the green in the display on my Sharp Carousel R-1460A microwave oven?
This model does not have a brightness adjustment for the VFD display.
It may be a weak VFD tube due to aging or it may be that the rear of the display window and front of the display glass are very dusty.
Sometimes you can clean it inside to brighten it up.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Some connectors have a lock.
positivelock.jpgIf that cleaning didn't help, then you have a weak VFD.
We can replace yours for $74.95. Details are here.
Oct 24, 2012 | Sharp R-1460 Microwave Oven
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
Digital display on MMV4205BA microwave oven is dim. How to fix?
It's usually a weak VFD tube, but in some cases it may be that the rear of the display window and front of the display glass are very dusty.
Sometimes you can clean it inside to brighten it up a bit.
Then you can detach the keypad connector (as per photo below) then remove the control panel screws.
Direct spraying of cleaners on the controls or keypad (and steam from the cooktop) can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
On this model, the VFD is not available separately, so you would have to order a new control circuit board for it.
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Sep 17, 2011 | Maytag MMV4205 Microwave Oven
The letter d on screen.turns on but doesnt heat
Your microwave is in demo mode, which means it will not heat. To turn it off touch and hold TIMER SET/OFF for 5 seconds until 2 tones sound and the "d" disappears on the display.
Aug 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Power is on, lights and front panel work, just no heat
There are a few definite causes but if you would like to rectify problem without messing around, i wold replace magnatron: capacitor and HV diode.That will certainly sort the problem out.
Sep 25, 2009 | Goldstar MV-1501 Microwave Oven
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
Kenmore 60654 Microwave Oven Logo
277 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
