Question about Kenwood LZ-700W 7 in. Portable Television
Kenwood LZ-7000 7 in. Portable Television
Hi guys,
I recently bought a bew *** import car and in it was a Kenwood LZ-7000 7 in. Portable Television with DVD player and also an added sat nav. I tried to play a dvd on it but when i put the disc into the player nothing happens and ive tried all the buttons but none seem to bring up the DVD. As it is a *** imort vehicle all the details are in Japanese and i cannot understand a word. I was wondering if you had any troubleshooting tips on how to fix this error or more imortantly is it possible to change the language.
Thanks a million,
Dean
  • lz-7000 Apr 17, 2009
SOURCE: Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Posted on Oct 05, 2007
  • 12 Answers
SOURCE: Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Posted on Feb 16, 2008
SOURCE: need a passcode
use the remote and press
5 two times
2 three times
2 one time
7 two times
KCAR
it should work if you have the remote it came with
RC-DV420 modle of the remote
Posted on May 15, 2008
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
SOURCE: ERROR CODE ON KENWOOD DVD PLAYER
According to manual:
http://inform3.kenwoodusa.com/manuals/DV5700.pdf
see page 73, end of 1st column to second column, 2nd papgraph.
Posted on Feb 27, 2009
Looking ahead
To convert the sat nav you just have to replace the card
Jul 07, 2008 | 1998 Nissan Altima
I have a 08 Honda Accord V6L with a Sat Nav V12
The earlier Honda models have a Mitsubishi DVD player for the SAT NAV Disk, ...and the 09 Models have different (Alpine DVD Player) thus earlier player will not read the later disks.
Solution is to obtain a updated disk produced for the Mitsubishi DVD player whih are available from Honda,(at a price)
Rgds
Dec 29, 2009 | 2006 Honda Accord
Missing operating instructions / manual for Honda Sat Nav system
did any of you find one? i have just bought a SECOND HAND 2004 CRV but no sat nav manual - nothing on the net- any help appreciated.
Jan 12, 2009 | 2004 Honda CR-V
Evesham Nav-Cam 7000/7500
hi mate the nav-cam 7000 and the 7500 are the same, i have the 7500 all of the data on the disc applies for the 7000 & the 7500 as far as camera updtes this is now in the process with the company that has taken over evesham, anyway you have to install active sync and use the cable to install the info onto the sd card, give it time and you should receive the sat signal unless it is stolen where then they can switch them off. good luck
May 11, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Kenwood DVR - 7000
Feb 21, 2007 | Kenwood DVR-505 DVD Player
Kenwood LZ-700W 7 in. Portable Television Logo
395 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
