Question about Nu-Vu NUV-MDO11 Stackable Deck Oven 1 Sheet Pan Electric
Nu-Vu oven will not reach bakeing tempature?
I have a nu-vu oven in my sub shop that will not get hot enought to bake the bread. It is a proofer oven combo. i have been haveing trouble with the switch on the door that tells the oven the door is closed and have replaced it. However now the oven doesn't get hot enough to bake bread.
  • Anonymous May 24, 2009
    oven does not reach temp
  • 3 Answers
Element I'm a subway tech
Posted on Jul 15, 2012
    Problem Solver:
  • 14 Answers
HELLO IM A OVEN TECH AND SEEMS THAT YOU MAY HAVE A FAULTY ELEMENT DEPENDING ON THE MODEL YOU MAY HAVE TWOO ELEMENTS ,ONE IS GONE ,
Posted on May 27, 2009
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
Nu-vu xo-1 convection oven temperature knob problem
Sounds like that nob is bad.can u get to see the nob wires to see what's up there?
Nov 14, 2013 | Ovens
GE Range JSP68 shuts off while preheating
I have an aging JSP68. First, take out the range control (held in by just a couple of screws, disect it, clean it the best you can, dry it. Be careful not to break it because there is no replacement. Pay special attention to the membrane buttons. They tend to stick. Realize the broiler element turns on sporadically to reach the set temp quickly, the bake element should be solid on. Check the "header" (the long double strip of pins) connecting the range control. I had to resolder mine. Another insult was that I baked a bread recipe that required you put water in the oven to generate steam. The steam made this oven literally go bonkers. The relays started to chatter and just a half minute of this will destroy them. Also when you press bake keep it pressed for a few seconds while adjusting the temp to 170 then release. If you don't hear the bake relay click on, try again. Another thing you could try is to press all of the buttons once, this should help to unstick them if any are stuck.
Aug 07, 2013 | GE Profile JTP18 Electric Single Oven
My oven is not baking properly. The tops of banana bread and cinnamon rolls are browned and bottoms still soggy.
It's possible the lower bake element is not working. If the oven takes a long time to come up to temperature, that's a good indication that a baking element (bottom, broil element is on top) is bad.
Apr 27, 2011 | Whirlpool GBS307PR Electric Single Oven
Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
The broil is the top element and the bake is the bottom element...so with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
heatman101
Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
Nu-Vu NUV-MDO11 Stackable Deck Oven 1 Sheet Pan Electric Logo
467 people viewed this question
Top Nu-Vu Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Nu-Vu Oven Expert? Answer questions, earn points and help others
