Question about Emerson Microwave Ovens
Put in food and then started pooring out? smoke smells like plastic??
  • Emerson Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
Food fire food overcooked and smoked in microwave bad odor and now the food is gone but the smoke odor is left. how do I get rid of the smell now. microwave itself is unharmed thank you, hank
You should be able to get a cleaner spray suitable for use in microwaves. Give the insides a good spray and a good clean, it should take it away. Make certain there is no burnt deposits anywhere.
Apr 27, 2017 | In Microwave Ovens
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
I placed food in the microwave over to heat for 19 seconds, when it was finished I smelled smoke coming from the oven. The food was fine. I unpluged the oven. I tried it a couple of days later, it...
the smoke probably came from the heated food. try using it next time with different kind of foods and also try it to the same kind of food that produces smoke but observe carefully what will happen.
Dec 29, 2010 | Emerson Microwave Ovens
Panasonic NN-CT776SBPQ, just 2 y old, burning smell advise what could be the problem and how much it cost\r\n
check if the smell is coming from within the cabin. If so due to non usage of food covers some food particles ccould have got stuck while on heat to the sides of the cavity and results in heating and smoking. If so clean well with a dry clot and wipe out any moisture on the magnetron fitting slot.
However if the smell continues, check the capacitor to the magnetron or the magnetron or the main transformer itself.
You must open the cover and check for the origin of the smell.
estimate cost and decide.
Creddit if the advice helps.
Aug 25, 2010 | Maytag MMC5000 Microwave Oven
Panasonic NN-T785SF microwave smoking and popping
Not to worry ,Please use a good torch light or lamp to look inside the microwave cabin. On the side where the magnetron is fixed look for any food particles which could have stuck while heating. Use a good cleaning solvent to do this job. You must remove all the roller and plates and clean dry. Once you have done this open the top cabinet with the mains wires disconnected. Look inside the side panels for dirt, insect which have got entangled and cooked. use a good brush and blower to clean dry. If the main capacitor has leaked replace with a similar type. Get help if you are not able to do this as it is a dangeorus section with high voltage. You will get to the smelling part once you had inspected these areas. Replace the part in question, can be even the surge protector at the mains end. Hope this helps. Good day
Jul 19, 2010 | Panasonic Microwave Ovens
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave died and started spewing smoke
Sorry but it sound like a component in the power circuit, transformer/capacitor/diode?.
if you feel capable to do the testing I can guide you
Feb 22, 2009 | Emerson MW8168B Microwave Oven
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
