Question about Mitsubishi WS-65513 65" Rear Projection HDTV
TV Repair I called last Sat when my TV broke down. I have one of your repair persons coming out tomorrow. How can I find out what time?
  • 927 Answers
Good day, rh3756;
I would recommend that you call the of service request and talk to live person or the service company's manager.
Good Luck, big IRISH.
Posted on Jul 18, 2008
Hitachi 60FX20B
Shop repair and very unlikely to get fixed in home
Aug 28, 2012 | Hitachi 60FX20B 60" Rear Projection...
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Designer SE and today while sewing the 'check upper thread' message kept coming up. There was nothing wrong with the thread and I rethread it several times after the message came up. I cleaned...
It's probably the sensor in the upper thread tension unit. If you look where the thread comes to the bottom before looping back up to the take-up lever, there is a small point coming out that holds the thread downward as the takeup lever moves up and down. Take a brush and clean any lint/dust out of that area or it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 08, 2010 | Sewing Machines
Sony kdl-46xbr4, horizontal lines
Sony is replacing LCD Panels at no charge until October 31 2012. The KDL46XBR4 and KDL46XBR5. If you paid to repair they'll pay you the cash back you paid to repair it.
Jun 11, 2009 | Sony KDL-46XBR4 46 in. LCD Television
First convergence problems, not won't turn on
The problem is the Convergence circuit and the reason it does not power up is that one or two of the 5a pico fuses have opened when the Convergence IC failed. It is either going to be a pair of STK392-570's or a single IC STK393-110. That is as long as this set is a Mitsubishi made in the last 7 to 9 years.
I would estimate the cost to repair 280.00 plus service call fee if any, plus tax on parts.
Let the Tech check it out. If if it cost less than 400.00 to repair, it may well be worth taking the chance.
Jun 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Broke ariel knob
yes it can be repaired.youll need to call a tv repair shop and have them come out and fix it but it shouldnt cost alot to repair
Jan 08, 2009 | Samsung HCN436W 43" Rear Projection...
Tv turns off on its own and now it will not power on
TV parts are only expected to work for 3-5 years. It could be the power board, or it could be a bad backlight. 500 dollar repair minimum, I suppose.
Nov 17, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Our display board was replaced now the y sustainer board needs replaced
Three suggestions:
Contact http://www.ptscorp.com/television.html. They have a selection of replacement boards or will repair it Fees are usually $50 to $125 and I have had great success with them.
Another would be to try www.shopjimmy.com and lastly do a Google search, if you know the exact part number, to find other sources for the board.
Sep 04, 2008 | Toshiba 50HP66 50 in. Plasma Television
Power outage / TV won't come on.
Call the manufacture tech support and ask them for their rep in your area. If it is possible for them to reset your TV I am sure that they will.
From your description, most of the time there is damage to the power supply, or one of the areas in the set.
Jerry G.
May 12, 2008 | Mitsubishi WS-55809 55" Rear Projection...
DIrectv Sat internal box.
You can try eliminating whethor or not the receiver is actually the problem by moving it to another TV and seeing if it works on one that isn't having any problems. Or moving a working receiver onto the TV to see if it will pick up signal with a working receiver. If you don't have any receivers in your house working, then odds are something needs to be serviced outside your home, like the Dish and/or LNB.
Did DirecTV actually come out to the home and troubleshoot at the site? If not, they would have no way of knowing if it's the TV or Satellite that's causing the issue.
Aug 09, 2007 | RCA F38310 38" TV
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
