My E.G. Air Cond.Compressor/condenser fan motor was replaced because it burnt; I replaced it with an O. Smith Electric Fan Motor. I also changed the capacitor. The new fan motor runs full speed for about 10 minutes and stops while the compressor is still runing. I need help to assure I have it wired corectly. I may need a manual which I do not have.
  • 828 Answers
These motors have a wiring diagram on the motor. Make sure you don't have two different speeds connected together.
Posted on Jul 11, 2008
The capacitor was bad and was replaced. now the system will work fine for about 30 min then the fan the outside unit will stop working. it sounds like the compressor is still on and cold air is will...
Yes, if you changed the three post capacitor that runs the fan and compressor, and the fan is still getting hot and shutting down until it cools off, you may have bushings out of the motor or an internal short. Sounds like you have a job ahead of you of changing your condenser motor. If you do this yourself just contact me I will step you through it . Mark
Jul 10, 2011 | Goodman CLJ36AR42 Air Conditioner
My air conditioner is blowing hot air. The outside fan in not wo
sounds like a contactor problem. this is the switch that kicks the outside fan amd compressor on. If the inside fan runs it will be on the outside.
Jul 08, 2010 | Whirlwind FH-778 Air Conditioner
Condenser Fan not working when the Air Cond is On.
There is a high pressure switch on the high side of the ac system,it most likely is bad.
Apr 06, 2010 | 1996 Mercedes-Benz C-Class
Why does my freg heat up between the doors
2 possible problem. condenser coils super dirty or you condenser fan motor need is out. clean your coils whit a brush, and vaccum (brush 5 doll harware store) cond fan motor is behin the fridge. lower part. the condenser motor run at the same time whit the compressor. if the com run and not the fan. you have bad fan
Apr 01, 2010 | Frigidaire FRS26R4A Side by Side...
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
My goldstar turns on and hums, but no cold air. then it blows a circuit breaker
First you should check the power for short circuit, second you have to check the fan motor if it is burnt or not,third check whether the compressor is burnt or not.These are the three reasons.If the powering is short circuited change the cables from the mccb.If the fan motor is burned out replace the fan motor or rewind the fan motor.If the compressor is burnt out replace the compressor, evacuate the refrigeration system and charge the refrigerant.
Aug 15, 2009 | Heating & Cooling
Compressor motor run in high ampere and then shut off
Check compressor capacitor to see if it’s good then check the contactor points and see if they are burnt or discolored if so then replace and make sure no wires are loose or burnt, then check the condenser coil to see if it’s dirty. Check to make sure outdoor fan is running and at full speed, if not then check the fan capacitor,and with the power and unit off spin the fan blade to see if it spins freely, if not the bearings are bad in the motor and it needs to be replaced.
Apr 20, 2009 | Haier hwr10xc6 Air Conditioner
Fan motor slow on a/c
If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
  • OR
    This could the problem the with short circuit or defective component you need to check :
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
  • Good luck....
    Nov 11, 2008 | Heating & Cooling
    GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
    I gather that it is the outdoor fan motor that runs a bit then stops.
    Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
    Jul 22, 2008 | Heating & Cooling
    Carrier Air Conditioner/Model # 38TG030300
    Hmm It's passable that the condenser fan motor is not spinning at speed or is running for a period of time and over heating and the Condenser fan motors internal overload protection trips and takes it of line shortly thereafter, of course, the compressor internal overload trips and takes it of line. Spraying with the water hose sped up the cool down on the internal overloads but I'm afraid it probably didn't do much to help the original problem. You could try replacing the Fan condensing motor capacitor-(it's listed on the side of the motor if the capacitor cant be read) and oiling the motor if it has oil ports (2 small plugs located along the perimeter of each end of the motor). If the motor can be oiled and you replace the capacitor theres a fair chance you might get by another year without replacing the condenser fan motor. Charged capacitors pack a nasty jolt so be careful, hope this was helpful, GL!
    P.S. If it is the cond. fan motor and you replace it be sure you get a sealed outdoor rated cond. fan motor and the appropriate rain guards are installed.
    Jun 12, 2008 | Heating & Cooling
    Heating & Cooling Logo
    138 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
