Question about JVC Cybercam GR-D72 Mini DV Digital Camcorder
Blocks of noise
When playing back a recording it almost seems like it is playing back in somewhat slow motion, sort of like a tracking issue. When I play back a previous DV that worked fine it now shows the same things. Can you help please?
    Problem Solver:
  • 11 Answers
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Posted on Jul 23, 2008
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
When I record a video using my Nikon Coolpix s4000, when I try to play it back the sound plays at normal speed but the picture is in slow motion! This happens everytime I record a video, is there anything...
Look for a Menu then FPS (Frames per second) option.30 fps should solve your issue. sometimes in order to keep file size low the setting is slower causing this issue.Good Luck.
Jul 29, 2011 | Nikon Coolpix S4000 Digital Camera
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
Quickplay on laptop plays everything slow motion and no sound, no sound for games most of time.
Are you running xp or Vista?
In XP go to device manager and expand list of IDE ATA ATAPI controllers. Right click on primary IDE controller and select properties. In advanced screen check primary IDE mode - that should be DMA.
IF that is in PIO mode - that is your problem.
Just click on driver tab in the same window and click uninstall.
REstart computer twice and problem should be solved.
Please leave your feedback if issue is solved
May 28, 2009 | Computers & Internet
Play-back on Roland VS 2400CD. Tracks recorded no signal or sound
There is an instruction DVD for the VS-2400CD. It is very helpful.
I couldn't have ever worked this board without it. Here's where to buy it;
http://www.amazon.com/gp/product/B000BSEUYI
Apr 01, 2009 | Roland Vs2400CD Digital Workstation W/CD...
Bad Video Recording
The cassette seems to be the problem .....change the cassette and check ....
Oct 26, 2008 | Sony Handycam DCR-TRV240 Digital Camcorder
Slow Playback
Sounds to me that the computer is way out of date. Chances are the computer doesn't have enough processing power to support what you're trying to throw at it.
It might help stop/uninstall all other programs running at the same time to give Cakewalk the best chance of working.
Nov 15, 2017 | Cakewalk Guitar Tracks Pro 2 Classic
Recording using A/V in jack - 18 seconds max allowed
Well there could be a couple things- A. there is a problem with the camcorder's software, which will need to be fixed by a LONG phone call with Aiptek Support B. You could be using the wrong component cables for your TV C. You could have the quality set TOO high for your TV's (The PS2 is NOT HD) I recommend DVD quality for this
Hope this helped, sincerely- animation508 (youtube username)
Jul 26, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Static on my mbox system
Well it all depends on what program you are using to record your music you will need to activate the noise reduction filter. or lower the volume on your mic but not on the program. Therefore your mic will not pick up any noise in the background and you will still have the same music quality.
Feb 11, 2008 | Digidesign Mbox 2 Barebone
Cannot play newly recorded cd's on any of our home audio systems, auto track or finalize.
UNFORtunately ive seen this many times, some systems only play originals and not recorded ones do to technology changes,
Jan 21, 2008 | Teac GF-350 CD Shelf System
JVC Cybercam GR-D72 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
