Question about Toshiba 27D46 27" TV
Toshiba 27D46 I have the same problem with the white line and a black picture. Is this TV worth getting fixed?? Thank You Gene
  • camms Aug 28, 2008
    Had the same problem with my 27" Toshiba so I took it to the repair shop They replaced the rectifier and now all is well. Cost me $80.40 total to fix.
  • 1,512 Answers
Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
Posted on Jul 13, 2008
Go to av mode without remote in toshiba 27d46 tv
Here is a manual for that tv. Page 27 says to push the tv/video button but that is on the remote. Do you have a tv/video button on the tv itself? If so, push it until it cycles through to the video input you want
Jul 28, 2012 | Toshiba 27D46 27" TV
Toshiba 27D46 27" TV Problem
it should cost you from $50 for dry solder joints up to about$120 for a rebuild of the vertical stages.
Jul 11, 2008 | Toshiba 27D46 27" TV
I have horizontal lines running across a two to three inch section at the top of the set. Is there a way to fix this? Maybe a way to ajust the vertical sink? These lines show always regardless of video...
From your description it sounds like a vertical problem, the IC in the vertical sector may need to be resolded or replaced, there are 2 or 3 capacitors that should be checked that are very near the IC. This is a very common problem with Toshiba sets, and are worth getting repaired.
Dec 20, 2010 | Toshiba 27D46 27" TV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
DVD only plays in black and white on my Toshiba 27D46 TV
Check on the dvd menu for the video format maybe that´s the problem
May 16, 2009 | Toshiba 27D46 27" TV
Sides of picture cut off on Toshiba 27D46
Check for dry capacitors on the tv board
Jan 19, 2009 | Toshiba 27D46 27" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Toshiba Color picture is black and white
Good day.
The missing color issue can be resolved by resoldering the loose contacts in your units circuitry. Your unit is still worth to be fixed.
Response is highly appreciated.
Mar 13, 2008 | Toshiba 32A50 32" TV
Rca projection screen problem
I have a Toshiba 27D46 TV that comes on great.. but within 5 minutes goes black with a white line horizontal midway across the screen. Any fix solutions? HELP..!!! Chip
Jan 06, 2008 | Televison & Video
Lightning strike
I have the same tv, but the problem I have is the picture is shifted to the right and can not correct it. At 1700, its probably not worth fixing because to expensive to repair, they dont make it anymore
Dec 27, 2007 | Panasonic CT-36D32 36" TV
Toshiba 27D46 27" TV Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
