Low Heat ? i have a brand new napoleon grills. paid a lot to get quality. I dont find it very performant. It seems there is heating problem. I read a lot about regulator reset. I tried it but im not...
Not sure what you're grilling, that would require 500 degrees or higher. Unless, you're really trying to char-broil and I do mean char. In any event, it may simply be the thermometer on the hood of your grill, reading incorrectly. Keep in mind, the thermometer is not reading the temp at the cooking grate surface, it's reading the air temperature when the hood is closed.
I do a lot of grilling, I do grill shows for local food stores and I love to grill. But, I have learned to never rely on what the grill thermometer says. I use an oven thermometer that sits off to the side, on top of my grill grates. When I compare the temp on the grill thermometer to the oven thermometer on the cooking grates, there will be a difference of 50 degrees. Now, certainly the temp will drop some, when the hood is opened after preheating. That's normal. But the heat loss, at cooking grate level, is not more than 10 degrees, depending on the outside ambient air temperature. Of course if it's the dead of Winter, the temperature will drop significantly. In that case, grill with the hood closed 90% of the time.
With all of the above said, what do the flames and flame heights look like on each burner? Do they respond as they should when you raise and lower the flames? If not, then you have a gas pressure problem. That can be resolved by turning OFF the tank valve, disconnect the hose from the tank and waiting 5 minutes. Then reconnect the hose to the tank and open the tank valve VERY, VERY, SLOWLY (slow motion, slow). Once the valve is fully open, light the burner farthest from the tank first and turn it to high. Do the flames look higher than they did previously? If so, light the remaining burners following the same procedure as the first burner. Do all the flame heights look correct. If so you solved the problem of low flame height.
I hope all of this has helped you troubleshoot and solve the problem, if there is one. Please let me know. Thanks and Happy Grilling!!
What about the spark(striker) not lighting the BBQ?
No it is not sparking except on rare occasions
