Question about HP Pavilion a1240n (EG136AA) PC Desktop
Firewire I bought an Apricorn external hard drive and it has a firewire cable and no power cable.  The drive worked immediately when I hooked it up to my macbook pro.  When I hooked it up to my HP, the drive light flickers and nothing happens.  It's almost like the firewire ports don't supply enough power to operate the drive.  Any suggestions?
    Master:
  • 413 Answers
Firewire is a lot like usb in the power area if the drive is not getting power i would suspect the firewire port. firewire did not become very popular because of problems like these. You need to go down to a computer parts store and by a firewire card and that should provide enough power and bypass the on-board ports. Try to hook another device up to the firewire ports and see if they work if not install the daughterboard with firewire ports
Posted on Jan 14, 2009
I bought my camera used online. The DV cable input does not work. (Unfortunately I was not told about this problem.) I cannot pass the tape to my computer now because of the DV input problem. Does...
I recommend you, test the cable, the Firewire ports. test connection.
Plug the firewire into the camcorder BEFORE turning it on,
You must use a Firewire cable and FW ports (Firewire to Firewire) NOT USB port
Check the cable no bend.
1.- Try with other cable
2.- Try connect a different Firewire port on your PC (or connect to other PC)
3.- To test the FW port on your PC connecting other devices by example external hard drive
If the Hardrive work fine the problem is with your camcorder
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Panasonic DVX-100 Camcorder
I recently purchased an external hard drive, and how do connect it to my computer.
External Hard Drive is mostly of the USB interfacing type. If urs one is the same, then it is just as simple as plugging in a pen drive in the USB port. If it has external power supplies then u can easily figure out how to connect. There are two parts in the power supply (if external power supply cable is provided), 3-pin main power supply connector and other is the adapter which goes to the external hard drive.plug in the other end of the adapter into the hard drive (there is a hole in it). connect the main power cable to the adapter extension. now for the usb Hard Drive, connect the USB cable to the USB port of the computer. Switch on the power supply to the Hard drive and u r ready to use ur brand new External Hard Drive. If it is a Firewire interfacing one then u may need to open the CPU box, and then connect the firewire connector on to the motherboard firewire port. It is easy to identify, it is a red colored port/connector.
Oct 11, 2008 | Western Digital 500GB My Book World...
Won't mount
Western digital drives ****! I'm having the same problem repeatedly. Seagate drives work fine though.
May 30, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Fire wire usb external hard drive
if your computer has a firewire port, connect the hard drive to the firewire port.
If you don't have one connect the hard drive to the usb.
Don't use both.
May 13, 2008 | Western Digital My Book Essential Edition...
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Attach external hard drive
firewire adapters only fit into firewire sockets..if you don't have that upgrade, you most likely only have USB ports..
Mar 09, 2008 | HP Pavilion dv4000 Notebook
Hooking up My Book to my computer
Your MyBook has a choice of connections, either USB or firewire. You only want to connect the USB. Perhaps someday, you will want to connect to a computer with a firewire port, but without an available USB port, and your MyBook will be able to.
Dec 05, 2007 | Western Digital External USB 2.0 80 GB...
Hooking up a
Your external drive has a choice of USB or firewire, so only connect with the USB cable.
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
HP Pavilion a1240n (EG136AA) PC Desktop Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
