Question about Philips PM435S Remote Control
Don't have manual
Need set up code so it can turn on/off my sharp tv.
  • Anonymous Jul 13, 2008
    cant turn on/off
What is the 4 digit code for an Emerson TV
Posted on Jul 11, 2008
My tv sharp model 21v-fw650s locked due to ,i forgot the passcode how can i reset it to factory setting
There should be a default code, that overrides the set code, and using it you can reset it by an other code. Refer its user manual to get this override code. Electro help Gopakumar Gopalan Google
May 22, 2014 | Sharp Televison & Video
How do I program a tv code into my remote
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Jan 05, 2014 | GE Tv Vcr Sat/cbl Remote Vsqs1495...
Need code for sharp tv
Dec 28, 2013 | GE 20621 Universal Remote Control 3...
I have a remote oneforall i need codes for a SHARP VCR please help need codes
There are two codes for Sharp. You'll have to try both to see which one works. 0048 & 0807. I am assuming you don't have a manual.
On the remote press and release the VCR/DVD button. Press and hold the SET button until the LED blinks twice. (it will blink once when you first press it, that doesn't count.) Just wait a few seconds. After it blinks twice, release the SET botton, and enter the CODE..
The LED should blink twice. Aim the remote at your VCR and press
POWER.. The VCR should turn on. If not, try the other code.
0048 worked on mine. Good Luck!
Aug 15, 2011 | Universal Remote Control Remote Control
Sharp LCD TV will not work with Uverse
Whichever device came with the remote will tell you how to program the remote in the manual if it is a universal remote. You can obtain a manual from their websites if you dont have one. I have a list of codes from my Comcast Cable Universal remote. Denon's are 1104 or 1360. Sharp tv are 0165 or 0093. These codes may or may not be the same, but you will still need a manual for the remote to learn how to program it. There so many different features with each individual piece of HI-FI that I still need all of the remotes anyway. The best advice for you is to just buy yourself a nice remote caddy\organizer. I have installed a little shelf next to my bed for all 7 of my remotes.
Aug 31, 2009 | Denon AVR-1908
I cant tune in my tv its a sharp dv5103h abd i have lost the manual
Dear customer,
Sharp TVs often require you to press the TV Tuning preset key which is a yellow function key.
   Setting Up Your Sharp TV
Turn on your TV.
  1. On your Tune In remote, press TV and release.
  2. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  3. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  4. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
U can also refer to the following link for ordering manuals  http://www.aerialsandtv.com/tvservicemanualsmainpage.html
Plz rate this solution..
Apr 09, 2009 | Sharp Televison & Video
Remote won't work and power switch pushed inside the television
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
May 15, 2017 | Sharp 25N-S100 25" TV
We need the code for our sharp t.v. We do not have the manual.
with the TV set off.
press and hold vol down on the tv set and push clear on the remote set for 5 seconds, if that dosent work you need a new eprom IC instaled in the tv set.
regards,
daniel.
Jan 09, 2009 | Sharp 27R-S50 27" TV
Need to set remote
Hi
Make sure you have set the correct code, For Sharp TV you need to use code 0093.
Also you can obtain the User's Manual with code list from the link below
http://www.expressfix.net/manuals/remotes/URC-3021
Aug 26, 2008 | One For All URC-3021 Remote Control
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Jan 01, 2008 | One For All URC-3021 Remote Control
Philips PM435S Remote Control Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
