Question about Toshiba Computers & Internet
My computer was very fast when I got it but now it is slow. I think if everything that has bin saved on my computer ,except the things were already on it, were erased it would run a lot faster. how do I restore my computer to factery settings and programs
  • 781 Answers
Simplest and easiest way is to completely reinstall O/S.for best results partition hard drive so that files or programs can be installed to 2nd partition and you do not lose them everytime O/S is reinstalled
Posted on Jul 10, 2008
I have a kenmore 80 series washer and everything works fine except when I choose a speed combination that has a slow setting for the agitation, it will not agitate. When I switch it over to fast /fast , it...
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem. The capacitors on the board need to discharge to completely depower the board. That why unplugging and replugging right away doesn't always work.
Oct 15, 2013 | Washing Machines
Ford Focus shakes above 67 mph.
bad/ or out of ballance tires or a bent wheel
Jun 15, 2012 | 2009 Ford Focus
Word crashes during the phase between label address entry using the Avery toll Wizard and the printable word document with the labels once you hit 'finish'
If Word launches fine, but crashes or freezes when you perform some function it is possible your registry's data key has become corrupt.
To fix this, you must close Word and edit the registry as follows:
Go to start -->run-->type regedit and press enter key ,
Navigate to HKEY_CURRENT_USER\Software\Microsoft\Office\9.0\ Word. (Note: the 9.0 refers to Word 2000, if you use Word 97, you will see 8.0, Word 2002 is 10.0, and Word 2003 is 11.0). Inside the Word folder, you will see a folder called "Data". Delete this Data folder and relaunch Word.
In many cases, there's some add-in you've installed that's causing problems (slow loading files, etc.) ... something that has to load with every document. One example would be Norton Antivirus, which includes an Office PlugIn that greatly slows Word down because it scans every document when you open it, which is totally unnecessary since Norton already scanned the documents when you added them to your computer. If you are running Norton, go into Norton's AV settings and you will see an option for the Office plugin -- remove that checkmark and see if that fixes your problem. However, if you are not using Norton, this is the kind of troubleshooting you will have to do, with any program you think might be affecting Word.
Another thing to check is the "fast save" option in Word. It is definitely NOT fast and causes major sluggishness in Word. Go to Tools>Options and click on the Save tab and remove the check from "Allow fast saves".
Feb 21, 2011 | Avery Computers & Internet
Computer very slow I just had more memorty put in cost 126.00 and still slow.help
try changing your power calliberation settings.. the thing is that the laptop is set to use minimal power to conserve battery life,, the downside to this is that it slows everything down.. To change this you can do one of two things,, right click the power connector / battery to the button right of the screen next to time,, and customise your setting to Perfomance,, apply and save it,, or you can go into control panel and power settings and change it from there.. There are different settings ,, actually ,, performance is hidden or needs to be customised ,, play with the settings and select perfromance (least battery life) it will make u run super fast....
PS.. this shorten battery life so you will need to recharge more often,,
Jul 04, 2010 | Compaq Presario M2000 Notebook
Please help! I am a bit of a perfectionist so when my zoo becomes quite full I find it annoying when everything moves with jerky movements and not at a smooth speed, sorry don't know how else to describe...
I usually never have that problem except if there are things installing or antivirus is running. This means it is because your computer needs to load too much details (because of the visitors and everything that is built). There is not too much you can do, except a few things that might make it slightly better.
A regular thing is defragmentating your computer, this will make your computer run programs faster. Mind that you can first uninstall all files on your computer that are useless, that you don't need. I am not sure about the version of your windows computer, but usually it's "Start" > "Control Panel" > "System Management" > "Defragmentate your hard drive" , then there should be a button "defragmentate now".
Slow moving screen is usually a cause of a slow computer, or a computer that has gotten slow. It is the common thing called "lag" on online games. So the only thing you can do is closing as much programs as possible that you don't need (try ctrl+alt+del, process tab and end what you don't need) for example msn or any antivirus.
There isn't a lot more you can do, maybe uninstalling, but I personally don't think it will have any effect. Try another computer maybe and see what it gives.
Jun 05, 2010 | Microsoft Zoo Tycoon: Complete Collection...
Error says: UNHANDLED EXCEPTION: ACCESS_VIOLATION (c0000005). What does it mean?
yea i have the same problem
i think its because i full-installed the game, cause this bug happens only when cinematics gotta play.
so yeah ill try to install multiplayer version maybe tonight and tell you more slow things down alot when playing on bnet, doing stuff fast tends to cause crashes and temp bans
Jan 24, 2010 | Blizzard Entertainment Diablo 2 for...
My Inspiron 2200 used to run fine; now it is ridiculously slow, which I think started after I updated everything after about six months our out of use. It's especially slow opening a browser and...
There a few things that slow your computer the way you described.
  1. You need memory on the hard drive that your Operating system is on. I would say 25% or more.
  2. Clear your temporary Internet,cookies and cache from you web browser (IE, FireFox, Opera, Ect)
  3. To many thing running in the background, if you are comfortable with computers (you can use "msconfig" to turn extra programs off)
  4. Defrag your hard drives
  5. As much memory as you can will always help.
I hope this helps.
Jan 22, 2010 | Dell Inspiron 2200 Notebook
When typing the text either freezes or misses letters!
Word is also notorious for leaving temp files on the system that can cause all kinds of problems. All of these files should be deleted by Word, but they often are not. The file names all begin with a tilde (~) so search your hard drive for ~*.doc and ~*.dot and delete any you find.
Jan 03, 2010 | Microsoft Internet Explorer 8
Computers & Internet Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
