Question about Konaki DV-6 Digital Camera
Need a new battery
This camera has a Li-ion Battery QLR05 900mAh Production Date 20051217. It isn't holding a charge for very long and I think it needs to be replaced but I don't know where to purchase one. Please advise.
Thanks,
Cheryl Kohan
It took ages but I found a supplier for the same battery.
http://stores.shop.ebay.it/STOREFERRY
He is extremely helpful and communicates in fluent english.
Posted on Aug 13, 2009
Asus 1101HA battery isn't charging
Is the battery a Nicad or Li-ion type, if Nicad, then that is the culprit.
Nicads are notorious for retaining memory from last charging, therefore the next charge starts from the last time it was charged. Li-ion batteries don't have a memory issue, so they recharge fully.
I hope this has been helpful.
Regards,
Peter
Feb 21, 2013 | ASUS Eee PC 1005 10 Inch Series 1101HA...
Tip
Samsung SLB-11A Battery
Batteries are very important, here has the best quality products and considerate service
Battery Type: Li-ion
Voltage: 3.80V
Capacity: 1130mAh
Color: Black
Dimension: 43.40 x 31.70 x 7.40 mm
Product Type: Replacement Battery (Brand New)
Condition: New, 1 year warranty!
Weight: 49.61 g
Inventory: In Stock
1. New Generic Samsung i8 Compatible Li-Ion Battery
2. Extra power for your Samsung i8 camera or camcorder
3. High capacity rechargeable Li-ion Battery with premium cells
4. Absolutely no memory effect so you can charge battery at anytime
5. Usually Ships Your Samsung i8 Battery in 24 Hours, 12 months warranty.
on Sep 21, 2010 | Cameras
My laptop battery is not charging properly??? what should i have to do?? plz!!!!!!!! reply
We need mark and model and date of purchase. It could be that the battery is worn out
Jan 17, 2011 | Computers & Internet
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
My Kodak Easyshare Z1485IS camera has a faulty internal battery, used to retain the date and time, how can I replace this battery Please?
I have this camera, except it is Pink.
I looked up the internal battery but I don't think it has it. I think that if your regular batteries get exhausted, it will lose memory.
I use Li Ion Batteries, as recommended by Kodak.
If your batteries are losing charge too fast, switch to the Li Ion type, and also keep a spare so that you can keep the memory by switching batteries quickly, within a few minutes, I believe.
Good luck on this.
Jul 23, 2010 | Kodak EASYSHARE Z1485 IS Digital Camera
My Kodak Easyshare Z1275 has short battery life. sometimes even newly charged 2600 MaH batteries cause problems. Powers up, lens extends, opens screen to set time and date then powers down. Sometimes i can...
wait, do you have Li Ion batteries or Ni MH?
I think that Kodak recommends Li Ion batteries which have a higher voltage on them.
I got some generic Li ion battery packs off of Amazon.com, with better specs. than Kodak, and they work fine for my Easyshare z1485 IS camera.
It cost me like $80 to get the charger and two battery packs that are Li Ion, but it's worth it.
My battery packs are rated at 2000 mAh 3.7 Volts each. It's the voltage that counts. You see, if you would split that in half, the voltage for each AA battery is 1.85V which is much higher than the 1.5V that regular Alkaline or Ni MH batteries are rated at.
I tried Alkalines, and Ni MH to no avail. But, the Li Ion batteries, did the trick for me.
Good luck on this 'repair' or battery upgrade.
Jul 23, 2010 | Kodak Cameras
Every time I turn the camera on, it takes 2 to 3 minutes to come on and always makes me verify date and time. Why?
This usually indicates that your rechargeable Li-Ion battery is starting to lose its ability to retain adequate charge due to age and usage (about 500 charges or 18 months of 'normal' use). Try putting a new rechargeable Li-Ion battery.
Hope it helps!
Jan 16, 2010 | Kodak EasyShare V1003 Digital Camera
My Z812 keeps telling me I need to reset the date/time every time I turn it on, even if I have just done it. Also drawing batteries very quickly (lithium, camera type)
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery.
I guarantee you it will provide stable longer power for on your camera
Nov 20, 2009 | Kodak EasyShare Z812 IS Digital Camera
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Konaki DV-6 Digital Camera Logo
306 people viewed this question
Top Konaki Cameras Experts
Are you a Konaki Camera Expert? Answer questions, earn points and help others
