Question about IBM Wheelwriter 30 Typewriter
Typewriter turns on keys work ,new ribbin, but when you hit the key no type shows on the paper
  • IBM Master
  • 3,594 Answers
The problem is probably either a broken plastic cap on the print solenoid or a gummy solenoid. the sol. is round and just unside the L. peinter side frame. Try a little WW40 on the front and rear ends of the solenoid if it doden't work the cap is probably cracked. They are available but a little tricky to install.
Hope this helps
DickyO
Posted on Jul 11, 2008
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
My Remington Noiseless 1939 typewriter has ghosting on the letter keys. I have put on a new ribbon but this just shows up the ghosting of each letter more than ever. I notice when typing the carriage
Could also be that your paper is too fibrous of finish. I found this page because my typewriter was ghosting, too. I adjusted some of the settings and there was not a trace of ghosting. I put the settings back and still no trace of ghosting. Then I realized that I tested for ghosting on paper that has a much smoother finish. I was ghosting on cheap paper we use here at work. So, I don't blame the typewriter. I blame the cheap paper. My typewriter just likes good paper.
Nov 14, 2011 | Office Equipment & Supplies
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
Hi, I have a 1967 Smith Corona Corsair portable typewriter with case. All works fine except that the ribbon does not lift when keys hit the paper. So the keys end up hitting the paper directly (not through...
Is the ribbon selector lever located on the right side of the keyboard switched to either red or black? If it's on white, the ribbon doesn't come up.
Michael
Jan 11, 2010 | Office Equipment & Supplies
Typewriter printing different key than one hit
Check and see if the pitch selection is in PS.
DickyO
Mar 29, 2009 | Office Equipment & Supplies
Keys are striking the paper but no black ink is printing on paper
If tou put in a two part form and it types on the second form the ribbon is either empty of not lifting up. If it isn't lifting up there is a large black gear on the rt. side of the printer, wiggle it back and forth they sometimes jam tooth for tooth.
DickyO
Dec 19, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
WHEN TYPING THE WRONG LETTERS PRINT
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Jan 25, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter
You need to select the TW position it is now in LP or JUST position, hold the code key down and press the 8 untill TW shows in the display.
Dec 10, 2007 | Smith Corona Wordsmith 200 Typewriter
IBM Wheelwriter 30 Typewriter Logo
55 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
