Question about Toshiba e-Studio 350 Copier
Cannot get the machine out of PM Maintenance mode
How can I reset the machine without doing PM on it at this time??
To reset PM counter : Hold down 0+8 together, turn on power switch, enter number (252), press (0) key, press ( enter) on screen, Shut down then turn machine on again.
Posted on Aug 21, 2008
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
I need to reset the pm flag on estudio 205L
power down the machine and turn the switch off. power the machine up holding and when it starts press 2 and start. this will put you in pm support mode. here you can select what pm counters you want to clear.
Jul 25, 2011 | Toshiba e-Studio 205 Copier
I have an estudio 350 that I need to reset after a "time periodic maintenance". How do I reset?
THIS MESSAGE APPEAR BECAUSE THE PM COUNTER IS THE SAME OR LESS THAN THE COUNTER OF PM'S UNITS (YOU CAN SEE THIS COUNTER ON THE 08 252).
YOU HAVE TO DO THE PM TO MACHINE. HOWEVER YOU CAN DO THIS STEPS TOO:
1.- TURNS ON THE COPIER HOLDING 08 KEYS
2.- ENTER 251 CODE AND PRESS START KEY
3.- ERASES THE NUMBER THAT SHOW AND PUT 0
Dec 09, 2010 | Toshiba e-Studio 350 Copier
Pm reset
F7-03, have a service technician clear/reset the PM count. NO reset button
Sep 03, 2009 | Panasonic Workio DP-2000P Copier
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Need service codes for this model
By default, after 74000 of PM counter, it will appear.
U can clear it if the machine is working fine.
Reset PM counter
08-252, set the value to '0'
To disable the PM counter,
08-212, set the value to '0'
May 06, 2009 | Toshiba e-STUDIO 282 Black and White...
Error Code SC570 for copier Aficio 1224C
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
Dec 17, 2008 | Office Equipment & Supplies
Thoshiba E studio giving the Total Counter 220320 number and display call for service. You are requested to advise.
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
Nov 16, 2007 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
518 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Richard Roth
Richard Roth
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
