Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Menu Button Does not Bring up the Menu
I have been trying to find a solution to the problems, but the online manual here directs me to page Q1 and Q4. I can't find those pages. Also, the menu button does not bring up any sort of menu. It worked in California, so I don't know why it doesn't now.
  • 138 Answers
I f it does not work with the remote or the set check and see if it is stuck if it still does not come up the problem is the small signal baord 313503711711.
Posted on Aug 19, 2008
Try holding in the front two volume buttons on the front of the tv.
Posted on Jul 28, 2008
How do I change the music playback feature to "random" file selection?
Is our question about an application like Spotify or Pandora or is it the operating system for the phone? If for the phone you will need to identify the make & model.
Jan 10, 2015 | Cell Phones
How do i set arlec pc 899 powerpoint time ??
Q1. How to set on / off times?
A1. Shift the red actuator pin to the desired on time
shift the black actuator pin to the desired off time.
Q2. What is the shortest time interval?
A2. 15 minutes.
Q3. Maximum switching times?
A3. One "on" and one "off" setting.
Q4. Can you override?
A4. Yes, use the override switch.
Note: If the main power is turned off the timer will need to be reset.
To set the timer to the current time you will need to turn the dial in a clockwise direction until the smaller arrow (Line) on the front face is pointing to the current time.
Regards,
Arlec Customer Service
+61 3 9982 5111
Dec 10, 2014 | Audio Players & Recorders
How to fix not working touchscreen? Do i have to replace it?
The Samsung Q1 is a hybrid, ultra-mobile, touch-screen device that is basically a very small tablet PC. It features a 7-inch screen, weighs a mere 1.7 lbs., features a Windows operating system, doesn't have a built-in keyboard, and comes in a variety of configurations. The Samsung Q1 doesn't offer outstanding battery life, but you can make some moves to boost your computing time.
Dim the Screen
Dim the screen brightness. Four programmable application-launch buttons occupy the right edge of the Q1. One of these, the menu button, calls up frequently-used controls, including screen brightness. Reduce the screen brightness as much as you can, as it's one of the best ways to extend battery life.
Close Power-hogging Apps
Close applications and browser windows when you're done with them. Too many open programs drain the battery. Beware power-hogging apps. Watching a video or listening to music on your Q1 drains your battery life much faster than just using Microsoft Word or checking email. Turn off the Wi-fi networking when not in use. The built-in Wi-fi searches for a network when you're not connected, which drains battery life.
Properly Caring for and Feeding a Battery
Unplug the Samsung Q1 after the battery is fully charged. Leaving your Q1 plugged in 24/7 leads to some discharge from the battery. Consider buying a bigger battery. A 3-cell battery comes with most configurations of the Q1, but you can also buy a 6-cell battery to double the battery life.
Room Temperature is Best
Don't expose the Q1 to harsh conditions. Keeping the device in a blazing hot car in direct sunlight harms your battery life. If you use your Q1 in conditions above 95 degrees Fahrenheit, you can permanently damage the battery. Cold conditions don't harm the battery in the same way, but if you leave the Q1 in the cold, let it warm to room temperature before you use it.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Samsung Q1 Tablet PC
How do i set the ip address on hp laserjet 2300n printer
First let me state that the network cards on these printers are notoriously bad and fail very often. Before attempting any settings, use the arrow keys to bring up the information menu and then printer a configuration. If you have a network cable plugged in then the configuraiton page will print both the basic pirnter configuration page and the Jet Direct status pages which will show the currently set network information. If only one page pirnts then the card is not working, if three pages print the card is working and you will be able to follow the instructions below.
Press the menu button and then use the up and down arrow buttons until "configure device" is shown and press the checkmark. Use the up and down arrows until display reads "EIO" jet direct menu then follow these menu options
Arrow down until display reads TCPip press check.
Arrow down until it reads enable, press checkmark and change option to yes, press checkmark.
Next arrow down to config method press check and then choose DHCP or manual and press check. If you have a router it will automatically assgin an address to your printer when you set it for DHCP, if not, you will need to select manual and then manually input IP address, subnet and gateway.
Once you select manual you will have the option to input the IP address, subnet and gateway using the arrow keys and the checkmark.
Mar 28, 2011 | HP LaserJet 2300N Printer
Monitor is locked i can bring up the menu but cannot select anything
First of all, try holding down the MENU button for about 15 seconds.
Just in case you don't have it already, here is the link to the ONLINE USER"S MANUAL for that model:
http://support.dell.com/support/edocs/monitors/1700FP/En/index.htm
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
Please comment back here to this page if you have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
Feb 26, 2011 | Dell W1700 17 in. HD-Ready LCD Television
When printing with the hp color laserjet 2600n printer, continue to get a double gray images for words and pictures. I have follow all online hp directions to fix this problem with no success.
1. Make sure that the control-panel display reads Ready.
2. Press and hold the LEFT arrow (<).
3. Press the CANCEL (X) button and release both.
4. Press the CHECK button, 2ndary Service will be displayed. Press CHECK again to access.
5. Use the < or > button to navigate the secondary service menu.
6. To remove the secondary service menu from the menu tree, power-cycle the product.
- access 2ndary service menu
- run "clean ETB" to cleanup the belt
- set paper to heavy or cardstock, print 10 blank pages to celan up the fuser
- try printing something
- if issue perists, send something to be printed and before it comes out, open up the front cover to stop the printing process, take out the page from the cartdridge area
- if the issue is noticeable on the top of the page but not on the bottom, the problem is with the fusing assembly
- if the issue is noticeable on the top of the page and on the bottom, the problem is with the transfer belt or one of the toner cartdridges
Jul 24, 2010 | HP Color LaserJet 2600n Printer
Amana sxde25j high voltage board blown..
hi there,
you can try to this store to order the parts to be replaced part number & description was also indicated in HERE.
just let me know, for further assistance,
Apr 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Restting nextar q4-4
resetting the Q4-04 , direct from Nextar FAQ's >
press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully.
nextar q4-04 manuals and faq's
see if that works for you , straight from the manufacturer .
if you need more help , just ask .
J5
Jan 19, 2009 | Nextar Q4-04 Car GPS Receiver
Cannot copy Double-sided
Q1- What make and model of copier are you using? Q2- Which document feeder are you using?
Sep 26, 2007 | Office Equipment & Supplies
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
